HPOP test?????
Old Apr 12, 2015 | 04:28 PM
Edogsf350's Avatar
Edogsf350
HPOP test?????
how does one pressure test for air leaks??? truck is a 04/04 F250 with 198K ICP sensor in the valve cover. any sugestions
Old Apr 12, 2015 | 04:51 PM
robs97z28's Avatar
robs97z28
use the blow gun on top of the discharge tube to see if there are any leaks at the quick disconnect. remove the discharge tube from the top of the pump and branch tubes. there is a quick disconnect on the branch tube fo remove the discharge tube. push the black ring forward with two screw drivers or the correct otc tool. then you can apply compressed air to the branch tube with a rubber tipped blow gun. then listen for air leaks under the valve covers.
7-Piece Blow Gun Kit-18249HOM - The Home Depot
Old Apr 12, 2015 | 05:48 PM
Edogsf350's Avatar
Edogsf350
i used a blow nozzle as sugested and about 2 min. later found the seal in the front of the pump blown out. thanks for the sugestion
Old Apr 12, 2015 | 05:54 PM
robs97z28's Avatar
robs97z28
if it was me I would send my pump here to be rebuilt!
Diesel performance-Home | Diesel Speed and Marine
Old Apr 12, 2015 | 06:04 PM
Edogsf350's Avatar
Edogsf350
im looking at through bread diesel or OEM
Old Apr 12, 2015 | 06:21 PM
robs97z28's Avatar
robs97z28
the way he upgrades the pump. it is just about bullet proof as they come. if you go with oem, all of the common failure points are still there. plus his price cant be beat of $575 for rebuilt pump and rebuilt ipr valve.
Old Apr 12, 2015 | 07:27 PM
Edogsf350's Avatar
Edogsf350
just checked out his web site ii think i will give him a call tuesday
Old Apr 12, 2015 | 07:37 PM
robs97z28's Avatar
robs97z28
if you dont mind sending some time on you tube, he has some col vids on the hpop and ipr. you might get a better idea whom you are dealing with. I just replaced my pump last year. I am planning on sending it to him.
https://www.youtube.com/channel/UCvM..._hvpftb87cRJxg
cabloom300
Dec 20, 2014 06:26 PM
cope1972
Jul 27, 2014 06:34 AM
rwdfan
Jan 23, 2012 11:37 PM
superduty4x4
Mar 16, 2008 06:58 PM
Xtra8ball
Sep 9, 2006 10:03 PM
