how do I take off the crank pulley??
Old Jul 26, 2003 | 08:21 AM
dablack's Avatar
dablack
Sorry for the stupid question, but I've never had to pull the pulleys before. I got the four 9/16 or what ever they were. How how do I get the big one in the center. I have the correct size socket and a breaker bar, but I'm just turning the engine over. How do I stop the engine from turning over to break it loose?
Thanks
Austin
Old Jul 26, 2003 | 10:35 AM
georgedavila's Avatar
georgedavila
Screwdriver in the flywheel teeth at the inspection pan will work. You'll need a puller to remove the dampner itself.
Old Jul 26, 2003 | 05:59 PM
classic79's Avatar
classic79
Do you have to take the dampner off?
I think with the 4 bolts off the pulley is off, give it a wack and it should fall off its stuck.
Old Jul 26, 2003 | 07:46 PM
georgedavila
I thought he was taking the dampner off. you right, the pully should just fall off.
Old Jul 28, 2003 | 08:06 AM
dablack's Avatar
dablack
Yes, the pulley just fell off with a little pulling. Thanks for the help. Ya gotta learn some time.
Austin
