02 explorer steering wheel controls not working
Old Apr 8, 2015 | 07:33 PM
bkrohnb6's Avatar
bkrohnb6
Just purchased this vehicle. The cruise control and radio controls On the steering wheel will not work. It has aftermarket stereo , not sure if wiring from that would affect cruise control as well as radio controls. Cruise light does not even light on dash. Clockspring? Radio wiring harness?
Old Apr 8, 2015 | 08:15 PM
shorod's Avatar
shorod
The aftermarket radio should not cause the cruise buttons to not work, but another wiring issue or a clockspring issue could explain that. You'll need to do some more troubleshooting to figure out what else is wrong.
-Rod
Old Apr 8, 2015 | 08:31 PM
bkrohnb6's Avatar
bkrohnb6
Thanks rod. I will ohm the brake pressure switch, and check radio wiring to see if I can get either to work. If not, I'll change clock spring.
Masterofyard
May 3, 2017 04:16 PM
Wranglin4Life
Oct 30, 2014 12:07 PM
Dave2590
Jun 18, 2012 01:56 PM
TexasRebel
Sep 17, 2010 09:24 PM
Bigfoot151
Jun 2, 2007 02:55 PM
