Does anyone else here have IDS? I've had it for about a year now and all of the sudden I get an error message when I hook up my VCM. "Multiple VCM II's connected, disconnect all and try again".
I only have one connected. Disconnect the single unit and the message goes away, re-connect and same issue. Not sure if it's a problem with the VCM or the VCM software, but I redownloaded IDS and same issue came back. Anyone have any idea?
I had that happen once and called up www.dealershipcloseouts.com ran the ids cleaner from their website, reinstalled the software and it worked great. I believe you need to run the IDS cleaner.
