tranny removal question
Old Jul 25, 2003 | 07:05 PM
nzabka's Avatar
nzabka
I'm dropping my C6 tranny tonite to replace my rear seal. This is my first time doing this.
My question is:
Do I have to really drop the tranny fluid? Or can I leave it in. I have a tranny jack to to aid me.
Your quick response would be greatly appreciated.
Old Jul 25, 2003 | 07:33 PM
Mike W's Avatar
Mike W
Can't you just take off the rear extension? You will loose fluid when you do this.
Old Jul 25, 2003 | 08:56 PM
nzabka's Avatar
nzabka
Huh? Rear extension? It's a 2WD. It's just a big hunk of aluminum with fluid in it. I'm actually ready to unbolt it from the crossmember and the motor. Will I get fluid all over the place if I don'd drain it from the pan and torque converter?
Old Jul 25, 2003 | 09:12 PM
nzabka's Avatar
nzabka
Ohhh, I see now what your saying. I wasn't really looking to split it, just move it out as whole. Quick and dirty, and get her back in cause it's hot here in NE.
Old Jul 25, 2003 | 09:15 PM
nzabka's Avatar
nzabka
Oh, and which way do I turn my crank to gain access to the t.q. plug if I'm gonna drain it. The book warns me about turning it the wrong way but doesn't tell which way is right or wrong.
Old Jul 25, 2003 | 09:48 PM
Mike W's Avatar
Mike W
Turn it the same way the engine rotates. That way you can't be wrong.
Old Jul 26, 2003 | 03:17 AM
nzabka's Avatar
nzabka
It's clockwise while facing the motor. Tranny's out, rear seal is in, bedtime.
