Smog Pump
Old Jul 25, 2003 | 06:55 PM
95_Ford XL's Avatar
95_Ford XL
Smog Pump
I have a 95 F-150 with the 300 I6, Can I run the engine and be ok without running the smog pump?
Thanks Mike
Old Jul 25, 2003 | 07:06 PM
big4x4bronco's Avatar
big4x4bronco
Smog Pump
I don't think you can. My bronco has a 351W with V belts. The smog pump belt broke one time on a fishing trip without me knowing it. By the time I had figured out what happend, exhaust gas had traveled up the plumbing of the air pump and burned up the diverter valve for the pump. Basically, exhaust backflowed through the pipe and destroyed the diverter valve.
I could be wrong, but thats my experience.
Chuck
Old Jul 26, 2003 | 09:46 PM
steve83's Avatar
steve83
Smog Pump
Chuck
There are check valves in the system which were rusted out on yours - that's why the diverter valve melted. If the check valves are OK, the exhaust won't come back.
Mike
No, you can't run without the smog pump because your belt won't work without that pulley, and there's no good reason to dump it anyway. It's cheap & easy to replace if it's ruined, and it doesn't use enough power for you to notice if you deleted it anyway. Keep everything running like it was designed and the truck will be MUCH more reliable and easier to diagnose.
