Need some input 2009 F150
Old Apr 4, 2015 | 11:38 AM
tiny1's Avatar
tiny1
Moderator & CL
Looking at a 2009 150 that has the 4.6 3V in it. I know that this was the first year for this motor and transmission. Are there any major issues to be concerned with?
Old Apr 4, 2015 | 12:13 PM
Nalb1221's Avatar
Nalb1221
I don't think there are any problem in particular that you have to worry about. The 4.6 3v has been around for a while at this point they fixed whatever problems the 4.6 and 5.4 3v has on 08. I have a 2010 stx with the 4.6 3v, she was built at the end of 09 so I'm sure there's not to much of a difference. It runs great and I haven't had any complaints about the 6 speed trains and it has 88,000 now. Hope that helps a little, good luck.
Old Apr 4, 2015 | 12:36 PM
tiny1's Avatar
tiny1
Moderator & CL
Thanks and it does. Normally a manufacturer has some issues when they come out with a design and I have not heard much about this configuration.
Old Apr 6, 2015 | 11:05 PM
galaxie641's Avatar
galaxie641
'09 wasn't the first year for the 3V 4.6L, it was the first year they supposedly fixed the cam phaser problem in the 3V's but that seems to not be true, should also have the 1 piece plugs that supposedly won't snap off when they are changed.
The tranny's had some issues mainly addressed with the updated flashes.
Old Apr 7, 2015 | 10:31 AM
Ranger Lance's Avatar
Ranger Lance
Check out TSB 11-3-25 bulkhead sleeve connector for the transmission. At some point in time IT WILL LEAK. There is also a thread on it in this section; do a search for transmission leak. If buying from a dealer have them look up and perform the TSB.
Old Apr 7, 2015 | 10:57 AM
Ranger Lance
Also go to youtube and search for ford f150 6r60 & 6r80 transmission fluid leak bulkhead sleeve repair by fordtechmakuloco. He explains the repair in detail with video.
Old Apr 8, 2015 | 08:40 PM
mrrish79's Avatar
mrrish79
Agree with the bulkhead connector. Mine was leaking when I test drove mine amd they replaced it before I bought it. I gave the 5.4. I will say it takes some time getting used to the 6 speed amd the acceleration below 2000 rpms isn't the best. Nice at cruising speeds when you need to pass though
My98FordF150
Modular V8 (4.6L, 5.4L)
49
Aug 4, 2014 08:45 AM
danorules
2004 - 2008 F150
24
Apr 5, 2010 10:22 PM
tshannahan
2004 - 2008 F150
Apr 20, 2006 02:17 PM
JF5speed
Mar 21, 2005 08:38 AM
custom_truker
Feb 28, 2003 08:48 PM
