rebuilt turbo problems
Old Apr 3, 2015 | 03:06 PM
darrellhackney's Avatar
darrellhackney
I rebuilt the turbo on my 2001 f250 7.3 l diesel and now I dont have any power. I noticed the rebuilt cartridge was tighter than before i rebuilt it. It seems to be improving as I drive it. Could the turbo be loosening and will be ok.
Old Apr 3, 2015 | 06:10 PM
David7.3's Avatar
David7.3
If the cartridge was tight that is your problem, that should spin by blowing on it. I am alittle worried about it getting better? What is wearing out, it's not wearing in. The turbo is kinda like the main bearings, it floats on the oil, if the bushings were tight oil is not flowing around it, you should have polished the housing or bushings so it spun free with the turbo out on the work bench, meaning emery cloth very fine, turbos dont break in. you need a boost gauge to start, take the intake hose off and see if you can spin the wheel with your finger, a light tap and it should spin for a minute or two, if it does is the wastegate stuck open? all your CAC boots on, no restrictions on the exhaust or intake side. Is the warm up valve hooked up and not just flapping in your housing outlet? Get a boost gauge so you dont have to guess.
rollinblackcloud
15
Dec 28, 2011 01:44 PM
pbgsho2
Jul 25, 2011 06:25 PM
1bad04
Apr 24, 2011 12:32 PM
captgann
Jan 4, 2011 06:56 PM
GreenMonster7.3
Mar 4, 2008 10:13 PM
