What A Mess - Cooling System Help
Old Apr 2, 2015 | 05:47 PM
nmclella's Avatar
nmclella
Hey guys,
Going to try posting this in both the 6.0 and Excursion forums to get help from both sides.
I'm so stupid. I was flushing the truck last night, and I didn't finish before it got dark. Well I didn't refill the truck with coolant/antifreeze as there was still more flushing to do, however I did drain the water out. As I drifted off to sleep I thought... it shouldn't get cold enough to freeze, we are in April already.
Well, my worst fears were realized. Go to finish today and start to finish flushing with demineralized water. Fill up the degas bottle and I'm greeted with the sound of water... even though all the plugs and rad is closed.
Joy.
Unless I've forgotten to reattach a line somewhere (possible, but I think I checked everywhere) I've gone a broken something.
The sound is coming from behind the AC. It is a glug-glug-glug sound as the water drains.
It is draining out down the side the passenger side wheelwell and landing near the steps.
And I was so excited to have it all done... What a downer.
Any help you guys could throw my way would be way appreciated.
I am a noob mechanic and am in way over my head, as pathetic as that may sound.
Thanks,
Nate
Edit - I can take a video if that would help with diagnosing.
Old Apr 2, 2015 | 07:13 PM
mustang_309's Avatar
mustang_309
Originally Posted by nmclella
Hey guys,
Well, my worst fears were realized. Go to finish today and start to finish flushing with demineralized water. Fill up the degas bottle and I'm greeted with the sound of water... even though all the plugs and rad is closed. Coming from the area you describe I would think heater core.
Joy.
Thanks,
Nate
Do you have a coolant filter? I cant imagine even if it did get below freezing that it would have frozen water inside the engine compartment, passenger compartment or block just over night. I would run a hose in the degas bottle and see if you can find the source.
Old Apr 2, 2015 | 07:15 PM
nmclella's Avatar
nmclella
william_04_x and others have helped me narrow down the problem thus far over in the Ex side of things.
Its past the heater core shutoff valve. Some say I may have popped my heater core...
https://www.ford-trucks.com/forums/1...stem-help.html
Thanks for your response, appreciate it
Old Apr 2, 2015 | 08:57 PM
KIDkiser's Avatar
KIDkiser
That's what I was going to suggest.it might be leaking in passenger side floor board as well.
Old Apr 2, 2015 | 09:28 PM
nmclella's Avatar
nmclella
Thanks for the help guys. Found the leak. Look like some water froze and broke two lines up in the fender liner.
Here's the update
Thanks guys, now I'll get it fixed and back up and going.
Cheers,
Nate
nmclella
Apr 5, 2015 08:53 AM
82'Stepside
Kansas Chapter
26
Oct 25, 2009 10:44 PM
strokersace
May 7, 2009 04:41 PM
perryau1996
19
Mar 25, 2008 07:41 AM
FordF350Baby
Feb 29, 2008 06:32 PM
