Blower motor troubleshooting
Old Mar 31, 2015 | 02:06 PM
vettman's Avatar
vettman
Earlier today the blower motor/fan quit. I've verified that it's not a fuse issue. Is there some way to determine if it's the switch, or the motor, before I start the repair process. I kinda believe it's the switch because the fan had not been "acting-up" or making weird noises. Any ideas for the next step in troubling shooting would be appreciated.
Thanks
Old Mar 31, 2015 | 02:15 PM
greentruck72's Avatar
greentruck72
get a test light and start testing conections, how old is the motor, how old is the switch, personaly i have never had this problem. a test light is a good idea when you are trying the switch as well.
Old Mar 31, 2015 | 02:27 PM
vettman's Avatar
vettman
The truck is 39 years old; the switch was replaced once, 20 to 25 years ago. The blower motor is original. I know how to test circuits; just hoping to be able to do so without disasembling anything. I basically want to determine if any power is getting to the blower motor. Can this be done under the hood, or will I have to go under the dash? I believe there is also a resistor and/or relay in the circuit between the swich and the motor windings.
Thanks for replying
Old Mar 31, 2015 | 02:38 PM
bkaul's Avatar
bkaul
There are resistors (mounted in the heater duct) to reduce the voltage for low/medium fan speeds - if there's a problem with these, the high speed will still work as it doesn't go through them.
If you don't have A/C, the back of the blower motor is exposed under the hood - pretty easy to get to the wire on the back and check for voltage there when it's turned on ...
Old Mar 31, 2015 | 03:08 PM
vettman's Avatar
vettman
I do have factory AC and the fan does not run on any speed setting.
Thanks for replying
Old Mar 31, 2015 | 03:19 PM
HIO Silver's Avatar
HIO Silver
I'd use a voltmeter to check for applied voltage at different points along the circuit.
mad1doc
Feb 11, 2017 10:07 PM
sparkieg
Nov 28, 2008 10:35 AM
deadscout
1997 - 2003 F150
Jun 3, 2008 12:03 PM
Valkdaddy
Bronco II
Aug 9, 2006 09:55 AM
69crewcab
Nov 15, 2005 12:00 PM
