Today is the day........
I've considered doing a larger expansion tank with a quick connect for easy winterization but I hardly ever dry camp so I skipped it. I have one on the shelf left over from an RO filter system if I ever get inspired.
Dave, my Shurflow is variable speed. Their top units still are...
One thing I forgot to mention that I know helps a lot with quieting things down, is to get rid of any 90 degree elbows attaching to either the inlet or outlet of the pump. Once I did that, as well as adding the extra coil of flexline to the output side, things really quieted down.
Received 3,997 Likes
on
Thanks for the tips on the tanks. We don't dry camp much, so I'll likely skip the expansion tank on this RV, but if we upgrade in the next couple years to one with a larger water tank, I'll probably go for it. I may do a larger one with since our kids are such light sleepers. I'll just add the quick connect for easy winterization.
Received 6,693 Likes
on
Last week at the campground entrance I filled my trailer's fresh water tank full. It took a long time to fill 120 gallons. I almost had to order out for pizza. However, the status panel only showed two "bars" out of four possible. This is the second time I've had that happen. The first time I thought I just didn't get as much in as possible. This time I know it was full because it came spewing out.
Is there any quick fix to get the level correct? Could it just be a sensor wire that is disconnected?
Someday I'll upgrade to better sensors so I can get better granularity on how full/empty the tanks are.
The issue is whether or not you can get to your freshwater tank. You are correct that most FW tanks use a system similar to what our DEF tanks use. The sensors are literally metal pins in the tank with wire attached to each. the ground is at the bottom, and then 1/3, 2/3, FULL pins up the side of the tank. Could be as simple as the wire fell off at the tank, or worse, that the wire is separated somewhere between the tank or the sensor panel.
You could do a few tests at the tank end, and the gauge panel end, by closing the circuit between ground, and each of the sensor wires and seeing if the panel lights up.
on
Jim sometimes the noise your hearing isn't actually the water pump but the water lines pounding because of the pulsing water from the pump. Look for loose lines hitting against the trailer. I had a couple lines near the pump that I put in pipe insulation and it has helped settling the noise down.
To me, Ariens just screams "box store" brand. Walk into a Home Depot, Lowes, or Runnings...and that is what you see. Doesn't mean they are no good, but from a resale point of view (I own a small landscaping company, so I think about that)...names like ExMark, Scag, and Ferris are going to resonate quality and bring more money than Ariens.
I see this model offers a Kawi or Kohler option...the Kawi engine is also a "3rd tier" engine from Kawasaki (FX, then FS, then FR...). Probably a good motor, but not the top commercial level. As for the Kohler...my impression is they usually make good engines. I've only had a 25HP Command in the past, and it ran well. But my neighbor had the *identical* engine in his similar mower which leaked large amounts of oil and bent pushrods.
I'd also be checking the quality of the spindles. This is another area that cheaper mowers tend to "cheap out" because most customers are not looking underneath. But when a blade hits something solid like a hidden rock, spindle housings often crack and need to be replaced. Pricier, commercial-duty mowers generally can take many hits without spindle damage.
Just another long winded post. Lol. This decision is eating me if it isn't completely obvious.
I am mowing my 1.25 acre lawn with a 2006 JD X324 and 48" deck. It won't win any races but with 4ws, I can do my lawn in about an hour. Depends on how tall I let it go and how many times I have to dump the bags. I thought about going bigger when we moved here but really, an hour is nothing to complain about. I guess the only way I'd go bigger now is if I clear more of my land and make the yard bigger. Then again, I don't want to see any neighbors so that's probably out...
I'm currently at about an hour and a half if it's dry enough to mow the whole yard. And I have to double cut the front yard to make it look nice. If I had something that cut nice enough to only do it once I could save 15-20 minutes plus there. And I keep removing trees to make life better.
Ultimately the deck height adjuster on the Wheelhorse is archaic (like 60's) technology and tears itself (the deck shell) apart, and really digs and sinks into soft ground. I'm just over it, and want something new. I like shiny things. Faster would just be a bonus.
