Today is the day........
#2851
#2852
#2853
#2854
Tim, I am watching the 2017 section of the SD forums and keeping in touch with my dealer. It seems the guys online always have more/better info that my dealer. I do know for sure that tomorrow is the day the order banks open so the order guides have to be available then. You can't order anything if you don't know what's available...
Andre, agreed as usual. A van color on a SD doesn't do it justice but that shot has me longing for my next truck. As Tim pointed out, that's an excellent angle for a marketing photo... even if it is white.
#2855
#2857
Carl, on the TH vs. no TH question/ issue...................This thing might be the best of both worlds. The pin weight is pushing it for SRW though at 3250 dry. If I wasn't so cheap and my kayaks would fit...................Love the idea though!
https://www.granddesignrv.com/momentum376-floor.php
Rest of the 17 is growing on me..................BUT those dually fenders are still HIDEOUS, IMO!
#2858
In a toy hauler how much can you impact pin weight with garage weight....I guessing it's quite a bit?
#2859
GCWR is made up of fairy dust and unicorns. No one can say what it's based on so I could care less about it.
The garage weight thing doesn't impact pin as much as you'd think. Adding 1500# to mine only changed my pin weight a touch less than 200#. I guess that's not a small number but it's not what most folks would assume is proportional.
#2860
Thanks for the link Scott. I like the front living...all that I have looked at have higher pin weights. We won't need a large garage and if we could find one with the layout of the 380 with a sliding garage wall that would allow us to control the garage/living space and put in a sofa along the garage wall...all that didn't kill us on weight....I think we will have the perfect home for the next two years.
#2861
#2862
No, you're right Carl. The pin weight does go down. When I mentioned the difference pin, meant a reduction and not an increase.
#2864
Carl, if I may make a suggestion... I would go with a hitch with a little more capacity than the 18k Reese if your looking at the triple axle toyhaulers. I really like my B&W RVK3300 hitch. I believe it has a 21k capacity and works nicely with the Ford prep package. If you watch online, you can usually find a good deal. I found mine last spring for $745 w/free ship, much cheaper than getting the Reese from Ford. Just a thought....
B&W RVK3300
B&W RVK3300
#2865
