Today is the day........
In the past the truck under carriage was the same for all their plows, and people would put the big daddy V plow on trucks that had no business pushing them.
All this tractor talk is making me want to drop by the Orange Toy store again. A cab, HST and more power are all on my list for my upgrade. I would like to keep the loader I currently have, as well as my shredder, box blade, etc. That would save me some money - if the loader will fit the new frame.
I'd love a cab but the cab on the Grand L is factory installed and 10 grand! Yikes... If I was going to run a blower, that would be a must but since I prefer to plow, it's not really necessary for me. I see where you'd want the AC for your TX heat though Doug.
Chad, you did call BS if you went straight to Boss' website to confirm....LOL You kept it inside your head!
I've never custom ordered a tractor, Rodney...usually you pick your model and the dealer has one. They typically can add all the factory options like different tires, remote hydraulics, lighting, etc. Obviously cab / no cab is something that must come from the factory.
A snow pusher on a tractor works amazingly, or you can actually get power angle plows that work off the hydraulics (or power beyond) circuit. But for areas that drift, a blower is pretty nice.
Well, it's not a custom order Tyler. However, most dealers don't have either the model I would want set up the way I want. Finding a Grand without the factory cab is tough. It can't be added or removed either. Finding an L4701 is tough on it's own. Finding one with R4 tires complicates it further. Sure, adding implements that bolt on and connect the hydro lines is easy. However, certain things need to come specced a certain way when built and I'm a bit against the grain on what dealers stock in that regard. Even something like tires, most dealers would rather grab one already setup a certain way than start swapping things around. Will see what happens when I get some time to call around. There is a Kubota dealer right down the street from where I bought my General. I'll start there.
My dealer was willing to swap tires. You might consider R1 ag tires. I was an all R4 guy until this last one, but I decided to try ags. They have incredible grip...much better than R4. They don’t cause any more rutting than R4 unless the ground is soft and wet...then beware...but even R4s will tear stuff up in those conditions. I still like R4 tires and they probably are still the best overall compromise but I feel much more confident on wet grassy slopes with R1 tires.
Anyway, enjoy the hunt and feel free to reach out with any other questions I might be able to answer.
The heat is definitely a factor, but an equally important reason for me to want a cab, is all of the dust that I endure while mowing or doing dirt work. This tractor is what we could comfortably afford at the time, and I am glad we decided to buy it. It did help me figure out a few things to do differently next time though.
I mow about 2 acres, and I've contemplated getting a cabbed tractor for because allergies and dust tear me up in the spring and early summer (almost pulled the trigger for a cabbed B3350 about 18 months ago). However, I do quite a bit of work with mine in the woods hogging trails and what-not, and I don't think a cab would do well in some of these areas. If it wasn't for that, I'd be cutting grass in the cool, clean, comfy cab.
anyone have any experience with branson tractors? made here in rome ga
Seems appealing to me, still fully mechanical injection, with stand alone dpf that can easily fall off with no tuning needed.
https://www.tractorbynet.com/forums/...f-issue-5.html
