C6 Vacuum Question
Old Jul 25, 2003 | 08:45 AM
mtandorfer's Avatar
mtandorfer
Question C6 Vacuum Question
I have a 75 F-100, 360, with a C-6. I just had the 360 rebuilt, dropped it in, and now am connecting the vacuum hoses. I have 2 lines coming up from the transmission that come up behind the engine in the same place (in addition to the two cooling lines). I don't know much about transmissions. One of these should be the modulator, what is the other one?
Old Jul 25, 2003 | 09:12 PM
rclarke's Avatar
rclarke
C6 Vacuum Question
You may have a dual area modulator. Manifold vacumn to the end port and spark vacumn to the port nearest the transmission housing. You might consider replacing the modulator with a single area type and only hook up manifold vacumn.
