Bare wire in Distributor harness?
Old Mar 26, 2015 | 05:59 PM
pauldfixr's Avatar
pauldfixr
Question Bare wire in Distributor harness?
So, I'm chasing a coolant leak on my '95 E150 Conversion Van, 5.0 V8, and I notice the wiring harness to the distributor looks like it needs some attention. I start pulling the tape off the loom that's tattered and falling apart, when I notice that there's a two inch long section of wire that seems intentionally un-insulated! It is wrapped twice around a couple or three other wires going to the distributor socket connector. All of this is wrapped in about 3/4 inch aluminum tape (not sticky either), then bundled in the loom. Is this the way these are made intentionally? I'll put it back, because there's no problem with the ignition... just seems odd. Only thing I can think is that it is some sort of RFI suppression treatment.
Old Mar 26, 2015 | 06:27 PM
Franklin2's Avatar
Franklin2
You are correct. There are some sensitive signals that come and go from the computer to the dist module. The high voltage going out to the plugs can cause interference with this signal.
What I would do is go get some of that aluminum tape with the sticky on it, and try to re-wrap what has come off. Or I guess some plain aluminum foil with a a little help from some electrical tape would work ok also.
Double check the regular wiring before you do this. The other wires have been known to get frayed or bare, and get shorted against the foil.
DaizeeDoesIt
19
Apr 26, 2018 06:45 PM
Building_Fords
Nov 18, 2015 08:50 AM
74 F350 SCS
Oct 3, 2012 07:05 AM
Monster_Magnet
Feb 14, 2009 01:07 PM
77effie
Electrical Systems/Wiring
Apr 5, 2006 09:45 AM
