4.9 idle control
Old Jul 25, 2003 | 05:53 AM
Joe13's Avatar
Joe13
Question 4.9 idle control
I have a 94 ford f-150 4.9 5 speed, i have several problems with my idle .
1. it idles at about 800rpm and slightly hunts up and down.
2. the idle adjustment screw has been temperd with.
3. i can unplug my iac and seems to be no change in idle evenwith the adj. screw all the way out.
4. also has a gas smell at idle.
I have changed the following: iac, tps, coil, evp sensor,plugs,cap,rotor,cps ,wires, temp sensor, intake air temp sensor,
i have a restrictor plate at the egr, and no vac. leaks at the evp sensor, tested the ignition control module its good, cleaned the entire air induction system, and replaced the pcm. Ialso have these additions:
k&n fipk, jet super chip( truck does the same with or with out the chip in), power-aide throttle body spacer, msd 6-a ignition . no cat, 3" flowmaster exhaust,
the truck is timed at 10' adv. and at a idle about every.75 of a second the timing jumps to about 18' to 20' adv. and right back.
the air bag light flashes a code at me #32 three flashes two second pause then 2 flashes then a 9 second pause.
lacks power in 5th gear. I am absolutely lost please help
Old Jul 25, 2003 | 07:00 AM
socket40's Avatar
socket40
4.9 idle control
Check your fuel pressure,computer is trying to compinsate for low fuel pressure
Old Jul 25, 2003 | 08:12 AM
Van/TX's Avatar
Van/TX
4.9 idle control
Can't help with the other stuff but the code 32 for the airbag light indicates the clock spring behind the air bag is going bad. Mine did that for a while and then the cruise and horn went away. A new clock spring fixed all 3. Good luck.......Van
Old Jul 25, 2003 | 11:57 AM
steve83's Avatar
steve83
4.9 idle control
If backing the screw out with the IAC unplugged doesn't affect the idle, then you have a MASSIVE vacuum leak.
A '94 4.9L doesn't have a CPS. I'd recommend tossing the TB spacer and putting everything back as close to stock as you can. Once you get all the problems sorted out, then you can start putting the mods back on if you think you need to, but mine (a '95 4.9L in my '83 Bronco) will easily push my rolling brick up to 95mph, so I see no need to modify it.
Have you tested the fuel pressure with a gauge? Have you checked the FPR vacuum line for gasoline?
