Engine Coolant Temp
Old Mar 26, 2015 | 02:02 PM
smoke665's Avatar
smoke665
Engine Coolant Temp
2006 F350 6.0. EGR delete, studs, all the bulletproof upgrades. New radiator,and external filter. everything should be good. However the last couple of months I've noticed that after it's warmed up and towing a load the ECT will sometimes run 10-15 degrees different under the same load. On a steep grade the ECT may climb to 215 before the fan kicks in, but once it does it drops the temperature rapidly. What I'm talking about is running along with the ECT in the 200-205, range, no fan and suddenly seeing the ECT fall to 190, then slowly climb back up to the 200-205. Its' almost like the thermostat may not be opening all the way or there's some type of obstruction in the coolant passages. These are off my Scan Gauge. Everything else seems fine, Oil temps are right in line (except when I get the drop in ECT the oil temp holds pretty much the same, though it will start to fall slowly). No coolant loss. Not sure if I have a problem or not.
Old Mar 26, 2015 | 04:01 PM
dannyboy950's Avatar
dannyboy950
factory thermostat opens from 192 to 195.
Your numbers will be a little scewed since you are under load.
Delta is established by testing a full warmed engine driven on a flat road for 15 to 30 miles with no load at 65mph.
To me you are just seeing the thermostat opening and closeing from what I see.
Old Mar 26, 2015 | 05:32 PM
69cj's Avatar
69cj
Your temps look fine to me. Most people seem to be running on the cool side. Your temps are ideal in my op.
Old Mar 26, 2015 | 07:34 PM
WRABER's Avatar
WRABER
Not concerned about the range, just trying to understand why it would suddenly go down without the fan coming on, then gradually work its way back up to the level it was. Sounds weird but its like the thermostat is opening and closing, or there's some type of temporary obstruction. Only stated the last couple of months.
Old Mar 26, 2015 | 09:58 PM
LivingLarge's Avatar
LivingLarge
Pull the sensor, clean with brake cleaner...also use contact cleaner for the pigtail.
jstoddard
Sep 15, 2016 09:03 PM
orange57
Jul 30, 2016 04:11 AM
Dr G
Jan 10, 2012 09:50 AM
Gental Ben 2
Jul 11, 2010 04:55 PM
Benchwrench
Aug 28, 2008 04:20 PM
