Glow Plugs?
Old Mar 25, 2015 | 03:50 PM
Big Air's Avatar
Big Air
Glow Plugs?
I'm finding that unless I plug my truck in at night, I will not be able to use my truck the next day. It will start and run for about one and one half minutes before shutting down. Then it won't restart. Temperatures have been low 40's to high 30's at night. I did find that the glow plug relay was bad and that has been replaced. I'm just not sure if my problem is the glow plugs since it will start and run for a short time. Am I thinking right or am I missing something?
Old Mar 25, 2015 | 03:59 PM
Bill Kay's Avatar
Bill Kay
Don't think its the glowplugs. Have you checked your fuel filter?
Old Mar 25, 2015 | 05:46 PM
whitetmw's Avatar
whitetmw
Here are some tests which may be useful. I would start with #10 regardless of what you have already done.
echo=on
HARD START/NO START DIAGNOSTICS
**NOTE: A hard start/ No start concern with EOT Temp. Below 60F perform step 10 first.
Tools: Fuel Filter Cap Removal Tool / Flash Light / Tools Flash Light / White Bond Paper / Stop or Wrist Watch w/Secong Hand Sweep / DVOM
Step #1: Visual Engine/Chassis Inspection
Tools: Flash Light
Fuel Oil Coolant Electrical Hoses Leaks Check
Tools: White Bond Paper
Step #2 Check for contaminates Correct Grade and Viscosity Miles/Hours on oil, correct level.
Step #3 Intake/Exhaust Restriction
Tools Flash Light
Inspect air filter and ducts -exhaust system / Inspect exhaust back pressure device
Step #4 Sufficient Clean Fuel
a. Check if the WATER IN FUEL lamp has been illuminated.
b. After verifying that there is fuel in the tank, drain a sample from fuel filter housing at
key on.
c. NOTE: Fuel pump will run for 20 sec. at key on
Step #5 Electric Fuel Pump Pressure
Tools: DVOM / Fuel Port Adaptor and Pressure Gauge 0-160 PSIG
a. Verify that the fuel pump has voltage and gnd. present at key on.
b. Measure fuel pressure at the Fuel Bowl Test Port key on.
c. Instrument Spec. 45 PSIG min. / WOT Under Load =/> 42 PSIG.
* If pressure fails low, go to step 8c on the Performance side of this sheet to identify cause
Step #6 Perform KOEO On Demand Test
Tools: OBD-II On-Board Diagnostics, Phase 2 Vehicle Media
Communications Unit (Scanner)
DTCs set during this test are current faults.
Note: IDM DTCs displayed here could be current or historical faults
Step #7 Retrieve Continuous Trouble Codes
Tools: OBD-II On-Board Diagnostics, Phase 2 Vehicle Media Communications Unit (Scanner)
DTCs retrieved during this test are historical faults. Note: IDM DTCs are cleared when codes are cleared.
Step #8 KOEO Injector Electrical Self-Test
Tools: Bi-Directional Scan Tool.
a. All injectors will momentarily buzz, then individual injectors will buzz in sequence 1 through 8. IDM DTCs may be transmitted after test is completed.
b. Note: IDM DTCs may be historical if not cleared above.
Step #9 Data List Monitoring
1. Select the parameters indicated from the NGS parameter list and monitor while cranking engine.
Parameter/Spec:
a. V PWR / 10.5 volt min.
b. RPM / 100-150 RPM minimum
c. ICP / 500 PSI or 3.4mPa min.
d. ICPv / 0.25v – 0.30v
e. FUEL PW / 1 mS to 6mS
* V PWR -If indicating a low voltage condition, check battery voltage, charging system or power and ground circuits to the PCM. GO TO PINPOINT TEST A
* RPM -Low RPM could be an indication of starting/ charging system problems,
RPM indicated with the engine cranking -could be CMP circuit fault, check for Diagnostic Trouble Codes. GO TO PINPOINT TEST DG
*ICP -A minimum of 500 PSI (3.4 mPa) is required before the injectors are enabled. No or low oil in the reservoir, system leakage, injector O-Rings or faulty IPR could cause pressure loss.
*Go to section 4 step 9c in the PC/ED Manual for a detailed description on how to perform this test. Note: If no RPM signal is received, IPR duty cycle will default to 14%
*FUEL PW -Even though a 1 to 6 mS FUEL PW is shown, it’s possible the IDM did not receive the signal due to a CI or FDCS circuit fault or internal IDM failure.
Step #10 Glow Plug System Operation
Tools: DVOM / Stop or Wrist Watch w/Secong Hand Sweep
a. Glow Plug ON time is dependent on oil temperature and altitude. The Glow Plug relay comes on between 1 and 120 sec. and does not come on at all if oil temp is above 131 F.
b. Verify that B+ is being supplied on the large BK/W wire going to the Glow Plug relay.
c. Install a voltmeter to the glow plug feed terminal (two brown wires or center terminal on the shunt).
d. Using a Bi-Directional Scan Tool and EOT PID’s, verify glow plug "on" time.
e. Turn key to run position, measure voltage ("on “time) (Dependent on oil temperature and altitude) Relay on time Spec. Measurement 1 to 120 seconds B +
f. Note: Wait to Start Lamp "on" time (1 -10 sec.) is independent from Glow Plug "on" time
g. Glow Plug Resistance
h. Remove both 9 pin connectors from valve covers • Measure each Glow Plug resistance to Bat. Ground. Measure engine harness resistance to relay. .1 to 2 ohms
i. Glow Plug Connector to relay 0 to 1 ohms
FRONT
#2 #1
#4 #3
#6 #5
#8 #7
*Add 5 seconds to glow plug on time when above 7000 feet in altitude, but not to exceed 120 seconds.
echo=off
Scribble
May 30, 2017 01:38 PM
Hill55
Jun 21, 2015 05:21 PM
Loftatsea
Apr 30, 2015 05:23 PM
mustangman65_79
Apr 27, 2015 09:15 PM
jamesk9
Mar 29, 2015 10:32 PM
