Need help
Old Mar 25, 2015 | 12:01 PM
petree's Avatar
petree
Need help
I got a 73 highboy f250 . In front rims fit in back the lug pattern on rim is slightly to big. So I am wondering if I can take axel of older truck. It's dana 60
Old Mar 25, 2015 | 01:27 PM
78fordguy's Avatar
78fordguy
I dont understand your question. If you bought rims and they dont fit then lug pattern is wrong. If your asking if you can swap a different rear axle under your truck then yes. But you have to make sure the gear ratio is the same as the front axle if 4x4. Also make sure your driveshaft and ujoint will work. Not worth the trouble if all you want is different rims. Just buy the correct lug pattern rims.
Old Mar 25, 2015 | 02:54 PM
HIO Silver's Avatar
HIO Silver
Drinking and posting don't mix.
Old Mar 25, 2015 | 03:57 PM
gatorfor88's Avatar
gatorfor88
"Hiccup" "BURPPPPPPPPPPPPPPPPPPPPPPPPPPPP"
Redneck1465
WTB - Parts & other
17
Mar 1, 2013 05:14 AM
PurpleStickyPunch
Sep 1, 2012 11:45 AM
fyve0
Apr 6, 2007 09:19 PM
DUKHNTR4LFE
Feb 2, 2006 01:34 PM
