Tall 400 dual plane intake...US made
I am taking a poll to see what the viability is to produce a nasty dual plane for the 400. I am imagining a air-gap style intake about 6-7" tall. Budget, say about $499. It would be about $150 less then buying a Edelbrock air-gap and the spacer plates.
Realizing the edelbrock and Weiand only cost low $200, is $500 pushing it to much?
Tim,
I think there would be more interest in a modern hi-rise single plane myself - as there is no such intake on the market right now. Another dual plane? Most people will skip it just because it's "just another dual plane".
Making a new high performance single plane will interest more buyers that want to try something unique. I'm not even sure you'd have to give up much torque either. Some of your first dyno testing included a Holley Street Dominator that did quite well compared to the Weiand and Edelbrock dual planes.
I would be in for a high-tech high-rise dual plane. I had a guy in the shop a couple of days ago with an intake off of a new Modular V8, although I forget the size. But the length of the runners was amazing! They must be 3x the length of a normal intake and would have to boost the torque - much like the old Mopar rams.
Having said that, it was for EFI as you can't do to an air/fuel mix what you can with dry air. So, would this be a carb intake only?
Cant fit a tall manifold without chopping a hole in the bonnet of my 72 Galaxie, ain't gonna happen.
I have a Holley street dom fitted, but would like an air-gap of some type but cannot justify the extra price and mucking around of a 351 manifold and plates.
One more joint to seal also, shouldn't be a problem but well, it could be.
The question is this - where is the trade-off? At what point is it better to just make a tall single plane?
Tim has "proven" the new Weiand to over 500HP. Better to offer a new dual plane to gain 10HP or a new single plane to gain 40HP? I just don't know that the gains are there in a dual plane. I'd be glad to be proven wrong however!
Yes, hood clearance will be an issue. I have an Edelbrock Performer 400 on my engine right now, and with a 1" spacer it looks like I can only run a 4" tall air cleaner. A drop base 5"x13" was a tiny bit too large O.D., it fit, but wasn't going to work all that well once the engine started moving around 4-wheeling and stuff.
We have been doing so many Edelbrock air gap intakes with the adapter plates, that we felt to make that unit as 1 piece would be a good deal. Face it a large majority of the engines are in trucks with hood clearance.
As far as dual plane, the Midnight Modified had the Blue Thunder dual plane making 620 HP. So there is plenty of power potential for a dual plane yet.
I do feel a single plane will be a must.
My vote goes for a high rise single plane with a removable divider plate. A properly built 400 has low end to spare, if it gets too mushy add the plate (cuts down the reversion from large overlap cams). Also fills the gap between dual planes and high rise single planes. I would run the divider just so I could throw an o2 sensor in each header and tune my engine more accurately side too side. BUT I would definitely buy me a Performer RPM for a 400, if "they" made one.
Better yet, how about a manifold that incorporates a small dual plane that runs off the primaries and a larger single plane that runs off the secondaries. It would be tricky to wrap the primaries around the secondaries plenum, with the primary plenum located below the secondary plenum. From the front I imagine large handle bar mustache like tubes that wrap around the secondaries plenum to reach the primary plenum. This would give a strait shot too the front of the secondary plenum from the secondaries, unlike past designs. I would also focus the primaries along the left side of the intake port and focus the secondaries on the right side. (looking at the valve). I would call it the tri-plane. Doesn't TMI inc Tri-Plane intake manifold for the 400 Cleveland just sound bad ***? Imagine the low end response and fuel mileage of a dual plane, with the high RPM rush of a single plane.....
