Need some advice on a good license plate mounted camera and a rear view mirror to go along with it.
Are Gentex still the go to brand for good mirrors? Any advice on the brand of camera? I'd prefer one with the lines on it and a pretty good picture instead of some of those fish eye views where you can't really tell what you're looking at.
Chris, I haven't seen anyone talk about any other mirror brands at all. At the same time, I haven't seen anyone talk at all about rear view interior mirrors in the last couple of years. That leaves me with the assumption that Gentex is still the brand. If there is something better, I'd certainly like to know as well.
I bought and installed a tailgate handle camera to go with my 2013 tailgate and a compass, temperature monitor auto dimming mirror. Wanted to get homelink as well but too expensive for that. Camera works great, shows parking lines and you can clip the wire and make them go away. I supposed you could also wire a switch to make the parking lines show and disappear on command.
For license plate cameras, I bought a 30 dollar one off amazon and it worked for 4 years until i got this setup. I just drilled a hole in the bumper symmetric to the spare tire hole.
Chris, I didn't go with the rear view mirror model. I did a Yada brand like petrokiller posted above but went with the 4.3" version on Amazon for $118. 14' from camera to display in the Excursion and have not had any connection problems with it, even in the cold weather.
good picture, easy camera to install and the reviews said:
"This camera is waterproof to a rating of IPx7, which means it can withstand total immersion in up to one meter of water for 30 minutes. This will be especially useful for boat owners because it means you can use the Yada camera to back a boat into the water. It also means the camera will be impervious to rain or snow."
I have a Boyo hooked into my head unit, so I can't speak to the rear view mirror unit. I can say this: The color/IR units do better at night, and it helps if IR illumination is built into the camera.
The backup camera needs to see a very wide angle to catch everything behind the vehicle at close range, so it needs a fish-eye lens to do this. A flat image means a narrow field of view, and everything except what's directly behind the hitch will be out of the camera sight. This type of lens is good for seeing things at a distance more clearly, but that would make the camera no better than a conventional rear view mirror, except for hitching up to a trailer.
It's expensive to get away from the fish-eye effect, but it can be done. You would need lens correction processing in the camera or the display to "straighten out" the bends.
I bought the Peak wireless unit at Menards back around Christmas....$99 after rebate. It is wireless so susceptible to interference depending where you are, but so far mine has worked when I needed it. Wireless camera mounts to the license plate and nice windshield mount monitor.
So lots of general recommendations, but no specific ones?
I do appreciate the input so far, just looking for specific brands for the license plate camera. And any input on a mirror cheaper than Gentex.
This is for a car, not one of the trucks. I've got the Gentex self diming mirror that does temperature display and direction in my truck. The wife has the Gentex self dimming mirror that has back up camera and all the other stuff in her truck, but we used a bigger camera and mounted it in one of the holes for the license plate lights.
Don't have any holes on the car, so I'm looking at the license plate frame ones. Seems like they're $30 or $100. Is there a noticeable difference in quality between these two price points?
I gave a specific....brand Peak, available at Menards. For $99 and being wireless, I am happy with the results. It mounts to the license plate frame, so no holes.
It lists the Peak one that Sowaxeman posted above, now they are available for$75. Good ratings and 110 degree viewing angle - but the wireless signal is analog and can be susceptible to interference, plus no night vision. Easily mounts to the license plate mounting holes.
The Yada (#3) on the review has a bit better camera with night vision and a digital wireless signal so it isn't susceptible to interference like the analog ones. $120 - mounts to the license plate itself. Rear view mirror option available but don't know the cost.
But neither of these are rear view mirror displays.
The AGPtek rear view mirror setup (#8) is worth considering - camera got very good reviews, wireless (but analog), a bit smaller viewing angle, but shouldn't matter for a sedan - and only $50
Researching and deciding on a backup camera was a total pain in the a$$ when I went through it...............options, wireless or wired, resolution, grid lines or no grid lines, camera viewing angle, camera mounting, light or dark beer - etc,,,,,,,,,
