Surging problem at idle
Old Mar 23, 2015 | 03:02 PM
bstick2284's Avatar
bstick2284
Having an issue in My F-150. '07 STX ext cab 4.6L. When I'm at idle rpm or when i'm coming to a stop and the engine comes back down to idle, it will surge and sputter. Lately its even been dying out. It does this 8 out of 10 times the engine idles down. Other than that it runs like a fox cruising down the road. My first thought was the fuel injectors/fuel system need to be cleaned. I was wondering what anyone else's opinion was and if I'm on the right track what the best remedy is. My local oil change place whom I trust offers a fuel system cleaning service. Anyhow, comments advice appreciated.
Thanks!
Old Mar 24, 2015 | 09:04 AM
bbender85's Avatar
bbender85
without more details i would point to the vacuum system.
Old Mar 25, 2015 | 07:41 PM
54f150's Avatar
54f150
Is your check engine light on? If so, what is the code? Have you recently (6-12 months) changed your spark plugs? I'm having the same problem with my 07 5.4L. Code was showing a bad fuel tank pressure sensor, dropped the tank and changed the sensor, drove 10 miles, problem came back again. It's throwing the same code as if the new FTP sensor is bad. Only reason I mention the spark plugs is bc when the plugs were changed, they ran a fuel induction to burn off the carbon build up to make it less likely to break off a plug. Curious if this could have caused a problem in the fuel system that's causing the code for a FTP sensor?
Old Apr 4, 2015 | 09:03 AM
60DRB's Avatar
60DRB
It would help to know more. Mileage, maintenance history, etc.
Surging sounds like a vacuum issue, but you can also make some other quick checks...
-Inspect the FPDM for corrosion
-Clean the MAF sensor and intake manifold with proper cleaners
Old Apr 7, 2015 | 08:53 PM
FordGuy85's Avatar
FordGuy85
Fuel filter replacement?
Old Apr 7, 2015 | 08:54 PM
FordGuy85's Avatar
FordGuy85
Check fuel pressure with a gauge.
danmm7
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
22
May 28, 2018 12:53 AM
mhofmann86
Sep 22, 2015 03:45 AM
expy999
Jun 15, 2008 07:00 PM
