Pictures of Coils? 3/4 ton or 1/2 ton
Can anyone e-mail me a picture of what the bottom pirch for a 3/4 ton should look like? Im trying to figure out if I have 3/4 ton axles with 1/2 ton spring and I dont have a clue what Im looking at. I looked at a friend who has an 84 1/2 ton and it looks nothing like mine. Is there a web site that might have pictures?
It a dana or spicer Im not sure of that either. Yes, Im in the learning process...
Thanks
Thanks
Looking at the picture in your gallery you have 1/2 ton front axle with 3/4 ton brakes added to match the 3/4 ton rear axle. Both 1/2 and 3/4 tons use Dana 44 front axle. 1/2 ton uses coil springs/radius arms like you have. 3/4 ton have leaf springs. 80-later use twin traction beam axles instead of the solid axle.
Seabeetough ~
Try my website; maybe those pix will help you -
<http://www.beedzncomputers.com/truck...nginstall.html> and
<http://www.beedzncomputers.com/truck...ont/front.html>
Seabeetough ~ Fantastic yellow truck; exactly what I want mine painted to next year!!
I'm going to have to back out of this one, neighbor (thanks for posting the pix) - you've got a 4 wheel drive and that is nothing like my 2WD. I'm sure one of the other elder users will / can / would / should help you out.
Best of luck....
Best of luck....
that looks like it is a dana 44 standard 1/2 ton setup. it definetly looks like you need some new spring perches. i had a couple 79 1/2 tons that when i put the lift on it the springs bowed a little bit. judging by the rust on those perches i would say the springs are probably very weak also and would need changing. the 3/4 ton trucks used a dana 60 setup with leaf springs ( no coil springs ). hope this helps you out
Thanks that helps alot. Yeah I need a new coil spring perch on both sides also new coil springs. Thats why I was trying to figure out what I have I want to get new coils and figured sense I was going to buy some I might as well get some that will lift it a couple more inches.
Thanks again now I can spend the wifes money..
hath
10-27-2012 06:29 PM
BMW2
03-04-2010 09:08 PM
