Sponsored by: Real Truck
Supercab Door Sticker
Old Mar 19, 2015 | 12:17 PM
Raymond's Avatar
Raymond
Veteran: Navy
My 04 rear drivers side door is pretty much beyond repair due to rust. Is there a way to remove the door sticker to place on the new door? Or can you get a new sticker from Ford to put on the new door. I would like to be able to keep the info that is contained on the sticker.
Old Mar 19, 2015 | 02:12 PM
jpr38057's Avatar
jpr38057
I assume you are speaking of the info sticker with the vin # and a lot of other info on it. A dealer can get a new one but jumping through a few hoops. It takes a little while to get it.
Old Mar 19, 2015 | 02:32 PM
Shovelheadrob's Avatar
Shovelheadrob
Try here Replacement VIN Sticker, VIN Labels, Tire Pressure Label | Auto Data I found them when I was trying to source one mtself
Old Mar 19, 2015 | 04:37 PM
05F250DSL's Avatar
05F250DSL
Take a heat gun not sure if a common hair dryer well get hour enough. Heat from the back side with a one sided razor start to flirt with the edge. When hour enough it will come off without reading void. It is a tortuous process.
Old Mar 19, 2015 | 07:04 PM
clem1226's Avatar
clem1226
High speed cutoff wheel. If the door is junk cut out a nice square with the sticker in the middle and throw it in the glove box.
1972washington
Jul 22, 2013 10:15 AM
Psyclopse
Mar 25, 2012 11:49 AM
ayden2004
Jan 26, 2010 09:22 AM
pkenn7
Sep 2, 2008 09:12 PM
71LTD390
Apr 19, 2005 10:09 PM
