I want to know how many Speedo calibrations are left?
Today I went out to see how many I have left, did the key and reset thing, what came up was weird. It says "E 03” and that’s it.
I thought there was supposed to be some numbers after the second set of numbers.
The CAL is "CAL967" now I know this isn’t stock, and its not calibrated for the tires I have on my truck.
The reason I checked to see how many are left is cause I want to put 35"s on real soon.
Can I calibrate it, are there any left?
Thanks dudes
I believe that means you have 3 left, and you have to puch the button again to see what calibration code is installed. and you have to use the jumper to accually change the code.
