Speed density
Old Mar 18, 2015 | 04:55 PM
Sixtone's Avatar
Sixtone
Speed density
Okay so I have a 93 F150 4 x 4 302. I want to know what sensors and systems are involved with the speed density. I have search the Internet up-and-down couldn't find anything of use. I do want to keep it speed density because of the better throttle response. Any advice would be wonderful thank you.
Old Mar 18, 2015 | 05:39 PM
rla2005's Avatar
rla2005
MAP, ECT, ACT, TPS, EVP, O2, TOT & VSS (E4OD transmission).
What are you trying to accomplish here?
Old Mar 18, 2015 | 06:07 PM
Sixtone's Avatar
Sixtone
Im wanting to "rebuild" the speed density system because of the better throttle responce and simply because its got 253,591 miles on it. It could use some freshing up imo.
Old Mar 18, 2015 | 06:30 PM
Shadow944795's Avatar
Shadow944795
If everything is working as it should and nothing has been neglected plus all the sensors check out okay it would be a waste of good money to replace them all if you ask me. What engine do you have? 300 inline 6? 302? 351?
Old Mar 18, 2015 | 08:51 PM
daddylee100's Avatar
daddylee100
Plus the new one's are junk anyway imo.
Old Mar 18, 2015 | 10:09 PM
Sixtone's Avatar
Sixtone
The truck is a 302. Its got a lot of problems that i want to adress. The speed density system is the starting point i have chosin. How can i tell if the o2 sensor is bad?
Old Mar 19, 2015 | 08:20 AM
LeoJr's Avatar
LeoJr
Emission related sensors (like the O2 sensor) will cause the "Check Engine" light to trigger. I presume your CE light illuminates when your turn your key on?
Still not sure what 'problems' you are trying to address though.
Old Mar 19, 2015 | 10:08 AM
rla2005's Avatar
rla2005
X2......
What issue(s) are you having?
Have you checked for codes?
Old Mar 19, 2015 | 03:12 PM
Sixtone's Avatar
Sixtone
The truck runs really choppy. The spark plugs are brand-new. The wires are 8 1/2 mm brand-new. it has great throttle response but is very choppy when it's running. By choppy I mean it runs like it's missing. After it warms up it runs fine no problems.
Old Mar 19, 2015 | 03:25 PM
88F15095F150's Avatar
88F15095F150
Did you replace the distributor cap and rotor along with the plugs and wires? I had a 89 F150 with the inline six that would run very choppy as well, but after a full tune up (plugs, wires, distributor cap, rotor) it ran fine. Most misfires in the ignition system will present themselves under a hefty throttle load because the weak spark does not have enough volts to ignite the air/fuel mixture under load.
Old Mar 19, 2015 | 03:37 PM
Sixtone's Avatar
Sixtone
Its got brand new MSD brass cap and rotor with a new MSD coil.
Old Mar 19, 2015 | 05:26 PM
LeoJr's Avatar
LeoJr
Double check the spark plugs wire routing. Do you know the firing order?
(Not trying to insult, just asking.)
Shadow944795
May 16, 2015 06:01 PM
Rambo76
Dec 24, 2012 10:32 AM
tucan69
13
Nov 4, 2007 04:18 PM
pyro3256
Nov 26, 2006 06:53 AM
