Vibration in drive train
Old Mar 18, 2015 | 10:05 AM
jspringator's Avatar
jspringator
My X has had a vibration in the drive train since I bought it. I have been through 3 sets of tires and a new rear end with no significant change.
I recently replaced the u-joints, and the vibration changed. Instead of being pronounced upon deceleration, the vibration was somewhat lessened, and only occurred around 55 mph when the truck was neither accelerating or decelerating; when the throttle and speed were at an equilibrium. It was reduced further when I reduced the air pressure in the tires. It is reduced, but is still there.
I would like to get this fixed before my spring break trip.
Any ideas?
Old Mar 18, 2015 | 11:33 AM
01FordEx's Avatar
01FordEx
Have you had the rear driveshaft balanced? I recently had similar issues, vibration near 65 mph, present whether on or off throttle. All u-joints were in good shape, same with CV assembly. From Ford there was run out at the tube to CV and balance was way off. Getting it balanced eliminated my vibe, no u-joints or other parts replaced.
Good luck!
Old Mar 18, 2015 | 02:06 PM
jspringator
Not yet. I was hoping the U joints would cure it. With my mileage, I'm sure I needed them anyway. I thought that would be my next step but I wasn't sure.
Old Mar 18, 2015 | 03:30 PM
Magnus E's Avatar
Magnus E
Good luck!
Where does one get a tube balanced - dealer?
Old Mar 18, 2015 | 03:31 PM
Big Sky's Avatar
Big Sky
My pickup does the same thing @ 55 mph. When I had the tranny worked on they replaced the u-joints and it cured it for awhile but it came back....It's not a major vibration but definitely in the drive train
Old Mar 18, 2015 | 03:58 PM
jspringator
Around here all the mechanics send the driveshaft to Republic Diesel. I think I'm going to call to see if I can just drop the truck off there instead of paying someone to take the driveshaft over there.
Old Mar 18, 2015 | 05:09 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
One of my wheels is bent just a little and shows up at speed.
Old Mar 18, 2015 | 06:05 PM
jspringator
Since it changed with the new joints I'm probably on the right track. Wouldn't they notice a bent wheel when they balanced the tire?
Old Mar 18, 2015 | 10:16 PM
12valveEx's Avatar
12valveEx
Have you checked the fit of the slip joint? The male portion of mine was worn, female portion was okay. That's what was causing the vibration on my Ex. Replaced male spline with Spicer part. Rubber boot deteriorated causing the failure, had new rubber boot and grease zerk installed on slip joint when I had the driveshaft rebuilt.
Old Mar 19, 2015 | 06:21 AM
jspringator
Does the 2wd have this?
Old Mar 19, 2015 | 07:25 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
I took it to 3 or 4 places before they noticed it, it isn't bent much and most techs just do what the computer says.
Old Mar 24, 2015 | 08:51 PM
jdw1's Avatar
jdw1
Check and make sure your drive line is in phaze.
If you bought the truck new it more than likely is.
Free edgamaction below.
DRIVE LINE PHASING
Dave042
2009 - 2014 F150
38
Jun 25, 2024 10:35 AM
Towmanjbo
Jul 17, 2015 07:23 PM
fastgnat
Feb 9, 2011 09:27 AM
billmayo
1983 - 2012 Ranger & B-Series
Oct 13, 2003 12:31 PM
