4wd swap question
Old Mar 16, 2015 | 09:28 PM
96inline's Avatar
96inline
4wd swap question
Ive found a good deal on a wrecked 95 bronco with a E4OD that I would like to swap. I have a 96 f150 4.9 E4OD 2wd that i was considering making 4wd. Would there be any compatability problems, could I use the broncos E4OD, t-case, ttb and front driveshaft? Would this be a bolt-on procedure?
Old Mar 16, 2015 | 09:54 PM
JHAM's Avatar
JHAM
Anything is possible but it will be a lot of work to swap everything over. main concern being check that the gear ratio in your rear matches what you would be putting in. if not be aware you need to either swap the rear also or regear. personally I would not do this swap but if you are dead set on it good luck.
Old Mar 17, 2015 | 07:43 AM
rla2005's Avatar
rla2005
The Bronco parts will swap just fine. As noted previously I seriously doubt the Bronco has 3.08 gears so hopefully the donor has a complete rear axle too.
Old Mar 17, 2015 | 08:06 AM
exranger06's Avatar
exranger06
The Bronco most likely has 3.55 gears.
bnmc98
Aug 10, 2010 12:22 AM
MobtownGeorge
May 11, 2005 07:56 PM
Lee Lichterman
15
Aug 31, 2004 10:07 PM
teajay
Apr 6, 2002 10:26 PM
