Brake trouble
Old Mar 16, 2015 | 08:39 PM
Chris71's Avatar
Chris71
Brake trouble
Does any body know anything about hydronic brakes on ford dump truck ?
Old Mar 16, 2015 | 09:04 PM
85e150's Avatar
85e150
Welcome to FTE.
Well, if you mean hydraulic brakes, yes. BUT:
--you are in the wrong forum for brakes on large trucks. There is a large truck forum "up" from here:
Large Truck - Ford Truck Enthusiasts Forums
--BUT before you go there, what is the year and model of your truck? Do you have the VIN and warranty/data plate info?
IF your truck is an F350, you may want to post in the appropriate year forum for the lighter truck. F4/450 and up, go to Large trucks.
The more info you post, the better the results. "Large" trucks have a couple of different systems.
AND what problems are you having?
Gather the info and post in the correct forum.
thanks.
Old Mar 16, 2015 | 09:18 PM
Chris71's Avatar
Chris71
It's a f700 with brakes that work off a pump similar to a power steering pump
Old Mar 16, 2015 | 09:23 PM
Chris71's Avatar
Chris71
The problem I'm having when I press in the parking brake in it makes the pedal so hard you can't press it at all with one foot
Old Mar 16, 2015 | 10:32 PM
85e150's Avatar
85e150
Working this question here:
https://www.ford-trucks.com/forums/1...l#post15183818
Old Mar 17, 2015 | 07:01 AM
69cj's Avatar
69cj
Sounds like you have a hydroboost brake system.
57 ripper
Aug 31, 2015 07:43 PM
Chase Saxton
May 14, 2015 11:13 AM
Duane1982
Mar 31, 2008 08:19 PM
f600 fire truck
Sep 24, 2006 06:05 PM
fusioncom
21
Jun 19, 2006 12:09 PM
