No Tails
Old Jul 24, 2003 | 02:09 PM
desperado_18_2000's Avatar
desperado_18_2000
No Tails
My 82 F-150 has no tail, or marker lights when the headlight switch is pulled. I've checked the fuses twice and all of them come up good. I think i heard something pop inside the cab before the lights went off. I've checked all my bulbs and these are fine.... Anybody have any suggestions? Perhaps the light switch?
Thanks in advance! -Tim-
Old Jul 24, 2003 | 04:25 PM
Franklin2's Avatar
Franklin2
No Tails
If you have a test light, start probing the brown wire. You can start at the switch, and work your way out.
Old Aug 1, 2003 | 10:19 PM
83Ford351M's Avatar
83Ford351M
No Tails
see if your truck has a trailer wiring coupler, located under the bed near the rear, mine did, and went bad not tail lights till i removed it
