Sponsored by: Kumho
lowering
Old Jul 24, 2003 | 12:57 PM
travis c's Avatar
travis c
lowering
whats the easiest way to lower a 76 f100 2wd, about an inch?
Old Jul 25, 2003 | 02:21 PM
travis c's Avatar
travis c
lowering
or two inches
Old Jul 25, 2003 | 09:55 PM
travis c's Avatar
travis c
lowering
is anyone going to answer, this question has been up for a day now
Old Jul 26, 2003 | 10:27 AM
77lowrider's Avatar
77lowrider
lowering
If you only want 1 or 2 inches, remove your springs in the front, and cut out one coil at a time. DO NOT use a torch, if you "blue" the steel, you can throw 'em in the garbage. The best thing to use is a 4" grinder with a cut off sawblade. GO SLOW!!
The rear, I would try and find some lowering shackles. If you wanna learn, or read more about this, do a search for lowering a pickup. There was a huge thread about 3 weeks back that kept getting new posts. Good luck!!
