Starting Problem
Old Jul 24, 2003 | 12:31 PM
bain1js's Avatar
bain1js
Unhappy Starting Problem
I have an 86 F150 straight shift 300cid 6. Whenever you try to start it, all you hear is a kind of thunk like sound (solinoid?) . The starter does not turn over. You can turn the key off and on a few times and usually something will "catch" and it finally starts. I've been reading the threads and have seen similar problems but was wondering if anyone could shed some light on what to check first.
Thanks everyone.
Old Jul 24, 2003 | 05:30 PM
bremen242's Avatar
bremen242
Starting Problem
try this- turn the key to the run position, then jump the solenoid terminal to positive with a screw driver.
if it clicks, then you probably have a loose/corroded terminal or connection.
if it starts, then your maybe your key switch is bad.
Old Jul 24, 2003 | 05:32 PM
Rick_Ford's Avatar
Rick_Ford
Starting Problem
Mine will do that occasionally, but it has been a while. I have had it lock up real bad to the point I made my solenoid smoke a little.
It's only done it once or twice since I got my new motor. I had it hauled in to my mechanic the first time after new motor because it never seemed to "catch". By the time it got to his shop, it cranked right up.
He told me next time it happened to check the alignment of the starter, or maybe tap it with a hammer to see if that helped.
I was thinking about just replacing the starter, but the problem just went away, at least for the moment.
I hope this gives you some ideas. Let me know what you find!
Rick
Old Jul 24, 2003 | 06:51 PM
bremen242's Avatar
bremen242
Starting Problem
my starter in my 351W did that when i first tried to turn the motor over after it'd set for a long time. tapping on it loosens the brushes, after they sit for a while, they get stuck to the starter shaft.
Old Jul 24, 2003 | 10:55 PM
steve83's Avatar
steve83
Starting Problem
Check the battery terminals (that means: pull them off, clean them, and put them back on tight) and the nuts & bolts at the other ends of the wires.
Old Jul 25, 2003 | 07:30 AM
bain1js's Avatar
bain1js
Starting Problem
I checked my battery cables and the connections to the starter and they looked good. I pulled the column cover off the steering wheel and the rod going to the switch under the dash moves ok. I hate to think its the starter itself since I just replaced it a couple of months ago. The problem last night was once I got it started, it would not stop starting. It's kind of hard to fix something when it's working! It seems that once it "catches", it will continue to start until you let it sit for awhile.
Could the solenoid beside the battery be the problem?
I really appreciate everyone's responses!
Old Jul 25, 2003 | 08:58 AM
steve83's Avatar
steve83
Starting Problem
That's a "relay" by the battery, and yes, it could be the problem. It's only ~$18 at a decent parts store, and easy to change.
Old Jul 25, 2003 | 09:03 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Starting Problem
If you are getting the solenoid to click, I don't think the problem lies in your key. I would be willing to bet that the problem is your gound wire. Follow it from the battery, make sure it is grounded good to the frame and most importantly, to the engine block. It would probably be worth spending the $30 to replace all the cables and make sure they are connected correctly. There is nothing more important, however, than your ground connection.
Old Jul 26, 2003 | 08:01 AM
jrocco's Avatar
jrocco
Starting Problem
This sounds to me like a starter problem. It's easy to remove and most parts stores will test it for you for free.
Old Jul 28, 2003 | 08:30 AM
bain1js's Avatar
bain1js
Starting Problem
I came to the same conclusion last night. I plan to pull the starter and have it checked.
Thanks to everyone for their help with this!
Old Jul 31, 2003 | 08:33 AM
bain1js's Avatar
bain1js
Starting Problem
I replaced the starter and still had the same problem... I started checking connections again and the cable connection going from the battery to the relay module broke off in my hand! The terminal was burned inside pretty bad. I'm guess moisture got in it. I'll install a new one tonight. I'm pretty sure this has been my problem all along.
Old Jul 31, 2003 | 09:55 PM
DieselMan04's Avatar
DieselMan04
Starting Problem
i had this same thing happen to my 86 ford....make sure the battery posts are clean and since your connection to your starter is good i can bet money it is your solenoid....i had to replace mine...but try bypassing the solenoid with a piece of 8 gauge wire, and if it starts up then you solved the problem...but if it doesn't...you know it is not your solenoid
Old Aug 1, 2003 | 08:22 AM
bain1js's Avatar
bain1js
Starting Problem
Replaced the solenoid and it started right up. I'm thinking of making some sort of plastic shield to cover the solenoid to prevent water from getting in it. I seem to get alot of moisture where I park it and I don't drive it that much. Does anyone think this might be bad idea?
Old Aug 1, 2003 | 05:11 PM
bremen242's Avatar
bremen242
Starting Problem
being that it worked for 17 year before it broke, I wouldn't worry about it.
plus if you cover it, it might hold in the moisture as well
Old Aug 5, 2003 | 08:18 AM
bain1js's Avatar
bain1js
Starting Problem
No, this one only lasted about 1 year, but I guess your're right about holding in moisture. I'll know what to do the next time if it happens again.
Thanks
