Starting Problem
Old Aug 5, 2003 | 10:00 AM
gavin's Avatar
gavin
Starting Problem
if it's right next to the battery, if may be getting acid run-off on it, rather than just straight moisture. In my old 4runner, the washer reservoir was right behind the battery, and they'd only last about 5-years before the acid wore through the plastic.
Old Aug 5, 2003 | 06:54 PM
bremen242's Avatar
bremen242
Starting Problem
maybe a sealed battery is an order.. ?
Old Aug 6, 2003 | 12:32 AM
gavin's Avatar
gavin
Starting Problem
It's not actual acid leaking from the battery, it's acidic corrosion on the terminals that then gets washed down onto other components. Happens whether you have a sealed battery, or not.
