Ignition Problem
Old Mar 15, 2015 | 07:57 AM
SouthernBlues's Avatar
SouthernBlues
Ignition Problem
When I parked my truck last night, I turned the key off but it all of a sudden went very loose. Now it will turn back and forth with no resistance. I can turn it all the way forward and it will still engage the starter and it will start and drive fine but I have to unplug the distributor to kill the motor as the key will not shut it off. Plus, I have to unhook the battery when it's not running as all the power stays on (fuel pump, radio, etc) even with the key completely removed. What broke?
Old Mar 15, 2015 | 07:59 AM
SouthernBlues
Changed the Key Lock Cylinder and still have the same problem
Old Mar 15, 2015 | 09:41 AM
subford's Avatar
subford
You have a bad Ignition switch.
The key tumbler does not cause this as you have found out.
Old Mar 15, 2015 | 10:43 AM
bashby's Avatar
bashby
There's a cast aluminium piece between the lock cylinder and switch that breaks also. Could be that or the switch.
Old Mar 15, 2015 | 11:59 AM
tjc transport's Avatar
tjc transport
i ain't rite
i say bad ignition actuator. 99% of the time it breaks in a no start situation, but i have had 5-6 that broke in a start but no shut off situation.
Old Mar 15, 2015 | 03:58 PM
SouthernBlues
My brother works at ford, he told me to pull the column and he will take it to work and check it out
Old Mar 15, 2015 | 05:01 PM
tjc transport
i ain't rite
dang!! i just realized you have a newer truck. i never messed with one of those, all i did were the 91 and older trucks.
it must be nice having your own in house dealer mechanic!!!
Old Mar 15, 2015 | 08:56 PM
Phy's Avatar
Phy
TJC hit it, broken actuator.
BeerKnurd
Sep 27, 2011 05:08 PM
fourshizl
Electrical Systems/Wiring
May 4, 2007 10:22 PM
desertdave35
1978 - 1996 Big Bronco
Feb 14, 2007 11:37 AM
BRNN53
Mar 5, 2005 09:46 PM
