timing issues
Old Mar 14, 2015 | 11:37 AM
jereli's Avatar
jereli
timing issues
1978 f150 400... Trying to adjust my timing which appears to be waaaay off. I turned my distributor clockwise as far as it can go and now hitting my thermostat housing. I need to turn it maybe another half turn but out of room. How do I fix this? Thanks
Old Mar 14, 2015 | 11:41 AM
bkaul's Avatar
bkaul
Sounds like it might be off by a tooth - pull it entirely out, and put it back in with the shaft rotated a bit. The *right* way to do it is to manually turn the engine over to cyl 1 firing TDC, then put it in with the rotor pointed to 1, but if you're careful, you can just offset it a bit from where it is.
Old Mar 14, 2015 | 11:46 AM
arctic y block's Avatar
arctic y block
You can also move the wires around one hole in the cap.
But why is it out of time to start with? Was the dizzy taken
out for some reason? Or has the timing gear/chain slipped?
We need to know this to be of any help here.
Old Mar 15, 2015 | 01:46 AM
jereli's Avatar
jereli
I really have no idea why timing was so far off. I just got the truck and trying to run through it to get to hopefully pass smog which sounds like its gonna be a pain as I don't know what's all required on this truck to pass. I've read many different emission options came on these trucks and kind of confused on what all should be there.
So I ended up taking out the distributor completely out after getting the engine on tdc. Then lined up the rotor to point at number 1 spark plug wire like mentioned looks like it worked I was able set my timing to 12 BTDC. Thanks was easier then I thought.
Old Mar 15, 2015 | 06:44 AM
earthquake68's Avatar
earthquake68
Did you put a timing light on it to verify it was that far off? Did somebody replace the distributor? If the truck has been running, there's no logical reason for the timing to be a full tooth off. If it is, it's for one of two reasons, the timing chain is getting ready to break, or somebody set the distributor in the engine wrong. Timing doesn't just change for no reason. Make sure that's really your problem.
Old Mar 15, 2015 | 11:39 AM
jereli's Avatar
jereli
Yea I have a timing light. I believe the distributor was pulled out previously because the bolt for it was pretty stripped. It was running just really rough. Looking at my timing light last night I also might have made a mistake. It has a timing advance **** on it that may have contributed to looking like it was further off then I thought ... Its running a lot smoother then before though but something still seems off. I may need to adjust the carb.
Old Mar 15, 2015 | 04:20 PM
gatorfor88's Avatar
gatorfor88
Make sure timing is spot on before adjusting anything. And you do know to disconnect vaccuum advance before making any adjustments dont you?
Old Mar 15, 2015 | 04:58 PM
jereli's Avatar
jereli
Yes I unplugged the vacuum hose leading to distributor advance and put a cap. My valve cover also says unplug the throttle selonoid and have it in neutral for timing. That's what I did and set it to 12. Re checked it few times and hasn't moved from there.
Old Mar 15, 2015 | 09:00 PM
Jdeshler's Avatar
Jdeshler
X'2 on rotating the wires.. But again, what was the reason for moving the distributor in the first place?
Old Mar 15, 2015 | 09:38 PM
jereli's Avatar
jereli
The reason why I had to remove it was because I ran out of room when trying to set my timing. My distributor was rotated all the way against my thermostat housing.
Old Mar 15, 2015 | 09:48 PM
arctic y block
Yes but I for one am wanting to know why it was that
far out of time to start with? As to why was the dizzy out
in the first place to have it in wrong and hitting the T-stat
housing? Is this a new engine you just are putting together?
Or one you have been driving and this just happened?
Why was the timing off in the first place? Please give more
info on this engine so we can know what you know.
Old Mar 15, 2015 | 10:11 PM
jereli's Avatar
jereli
The truck use to be my dads..it sat in mexico for about 10 years then brought back to U.S. where it sat for another like 5 years in storage. It was worked on here by random "mechanics" that my dad knew. Engine was supposedly rebuilt here before being left at a storage place. And now its out of storage and at my house where I am attempting to bring it back to life and have it in good running condition to pass smog. When it came from storage it wasnt running too good. Too many "mechanics" touched it while in storage so not really sure what was all done to it.
Old Mar 15, 2015 | 10:20 PM
jereli's Avatar
jereli
Now there was a lot of vacuum lines just hanging around not going anywhere or plugged up by screws..PVS switches were broken. A lot small things were missing or needed replacing. So I don't know the exact mechanical history of it so I am sort of just starting from scratch checking all the basic things first. Its running now and timing is now spot on. Now dealing with trying figure the vacuum routing and carb adjustments.
Old Mar 15, 2015 | 10:30 PM
arctic y block
Okay, Cool info. Thanks Bud. That helps me if not others to
better understand what your dealing with. If it was me I think
I would basically just start over. Like figure prolly everything
is needing looked at to get it back running. I would start with
the timing gear set up and make damn sure it is properly installed
than go to the dizzy from there. Check timing marks and harmonic
balancer and make sure it all lines up on TDC. The timing gears may
well be installed wrong. Once on TDC let us know if all the timing marks
are lining up. Than pop the dizzy cap and see what plug wire the rotor cap
is pointing at. Than we can go from there.
Old Mar 15, 2015 | 10:34 PM
Jdeshler's Avatar
Jdeshler
Well weather its what's a previous problem or not lets work on getting it fixed.. Try rotating the plugs clockwise so the distributor will rotate back towards the thermostat then see if you can dial it in.. If you have to skip 2 spaces to get it right it wont hurt a thing.. Assuming you already lined her up tdc..
**I see the other posts now.. starting over would be the best thing
