Ignition worries
Old Jul 24, 2003 | 07:58 AM
shamous1's Avatar
shamous1
Ignition worries
Hi there,
We have a 460 in our dragster. We were running a magneto but had heaps of trouble with it so we opted for an electronic dizzy instead. We are using the std distributor that came with the motor. The trouble we are having is that we have just purchased a PC6AL ignition module to upgrade from the std one. The PC standing for ProComp electronics. Our dizzy has three wires hanging out of it and the module only has two wires that feed into the dizzy. What goes where and is it the right module type?
Also has anyone had problems with broken collets on std heads with std rockers?
Brad
Old Jul 24, 2003 | 02:13 PM
airharley's Avatar
airharley
Ignition worries
http://www.inliners.org/tech/tech8.html
This should help figure out what wires do what from the dizzy. I had the same problem with mine until I researched it for a while.
Old Jul 24, 2003 | 03:10 PM
georgedavila's Avatar
georgedavila
Ignition worries
Distributor basics are one wire to the coil, one wire to an ignition on source (through an ignition box, etc.) and one ground wire.
By collet do you mean the fulcrum washer the rocker sits on? Not me.
Old Jul 25, 2003 | 03:55 AM
shamous1's Avatar
shamous1
Ignition worries
By collets I mean the rings that hold the valves into the retainers.
Is the module the wrong one for the motor and what's the stdd module like as far as performance goes?
Old Jul 25, 2003 | 03:59 AM
shamous1's Avatar
shamous1
Ignition worries
and our motor is pre 1978
Old Jul 25, 2003 | 05:58 AM
georgedavila
Ignition worries
My apology, different terminology. I've always called them locks or keepers. I've never broken one. What valve train are you using, rail rockers, pedestal mounted or roller rockers?
I don't know what distributor you're using, but it sounds like the spare wire would be the ground wire with the other two connecting to your module.
Old Jul 25, 2003 | 12:03 PM
Mil1ion's Avatar
Mil1ion
Ignition worries
Is this a Duraspark II dizzy ?
Old Jul 25, 2003 | 06:11 PM
Hired Gun's Avatar
Hired Gun
Ignition worries
That magnetic pick up in the Dura Spark distributor is virtually the same one MSD uses in their racing distributor.
Old Jul 25, 2003 | 08:50 PM
shamous1's Avatar
shamous1
Ignition worries
I am in need of the same info as to which dizzy it is? A mate told me it was a Hall Effect dizzy. Anyone know for sure what it would be?
Old Jul 25, 2003 | 09:30 PM
Go Navy-Beat Army's Avatar
Go Navy-Beat Army
Ignition worries
Sounds like a Duraspark II dizzy, which is magnetic pickup just like an MSD. I'm looking at the instructions that came with my 7AL2. How many connections are on your spark box?
Old Jul 26, 2003 | 05:26 AM
shamous1's Avatar
shamous1
Ignition worries
Well we have a std module, I'm told is a Duraspark, which connects up fine with the dizzy. It has three wires going to the dizzy. Orange, White and Black from memory We have just purchased this multi spark module which only has a red + wire and a black - wire to go to the dizzy. The multispark box is a Procomp Electronics 6AL
Old Jul 27, 2003 | 01:34 AM
airharley's Avatar
airharley
Ignition worries
If you scroll all the way down to the bottom of the link I sent you it shows you that you only use two of the three wires from the dizzy. (+) to Orange and (-) to the other color(should be purple). Black / ground isn't used. But that is to use your 6AL ignition system as a stand alone vise a secondary to the original module.
Old Aug 5, 2003 | 10:58 PM
frog's Avatar
frog
Ignition worries
I wired in the msd as airharley stated. used the ford dist and removed the dura spark ignition and wiring. much nicer and neater in the engine compartment now. just make sure you have a good ground for the msd.
