95 f150
Old Mar 11, 2015 | 11:56 AM
DustyRoadTruckinn's Avatar
DustyRoadTruckinn
95 f150
My 95 f150 with 4.9l v6 speedometer stopped working and then my truck started to shift hard from 1st to second. Could the two be related?
Old Mar 11, 2015 | 04:57 PM
GoinBoarding's Avatar
GoinBoarding
Yes, need to fix the VSS signal to the PSOM to regain correct trans operation. You should have an E4OD transmission, fully electrically controlled. All sensor readings matter. BTW it is not a V6 but rather an inline 4.9L six cylinder (I6).
Old Mar 11, 2015 | 05:01 PM
DustyRoadTruckinn
Thanks ill start there.
Old Mar 11, 2015 | 05:31 PM
rla2005's Avatar
rla2005
If the odometer is blank then check Fuse 18 and 8. One supplies Keep alive power to the PSOM, the other is "hot" with the key in the Run position.
bigredtruck
18
May 31, 2019 07:25 PM
rigid1
Jan 17, 2019 09:49 PM
BRay09
Jun 18, 2011 11:03 AM
oldfordtrucksrule
Apr 28, 2011 04:31 PM
hiddenvalley
Electrical Systems/Wiring
May 10, 2004 11:46 AM
