89 302 m5od problem
Old Jul 24, 2003 | 06:38 AM
grappledad's Avatar
grappledad
89 302 m5od problem
here's the problem.truck running,in nuetral let out the clutch it makes a wirring sound.and when i shift it makes a slight grinding noise after it is in gear.its not grinding going into gear but after u catch the next gear.is that the clutch or is bad stuff getting ready to happen?it runs fine no slipping and it goes into all gears ok.also it does'nt do it down shifting.any thoughts?
Old Jul 25, 2003 | 06:12 AM
grappledad's Avatar
grappledad
89 302 m5od problem
bump
Old Jul 29, 2003 | 06:05 AM
grappledad's Avatar
grappledad
89 302 m5od problem
i stiil need advice on this one.i know you'r out there i can hear you breathing.
