Ribs in back panel of cab - What years/models?
My 1949 F-1 does not have ribs and looks way different inside as compared to my 1952 F-1 which does have the 3 ribs. Now the cab on my 1949 may not be original, might not even be a 1949, since when I bought this truck it came with a title and serial # from a F-8 claiming it to be a 1949 F-1. The guy I bought it from said that he and his dad pulled it out of a field in Northern Georgia.
1952 F-1 outside
1952 F-1 inside
1949 F-1 inside. The outside appears smooth, no ribs.
1952 F-1 outside
1952 F-1 inside
I'm not seeing a pattern; there are ribs on every year from 48 - 52; there are ones without ribs on every year from 48 - 52; some are big trucks, some are F-1's in each category. We really don't have nearly all the plants represented, but there are already outliers. Maybe the smooth cabs are "Monday morning builds"???
I'm not buying it. After 60 years, memories fade and trucks are modified. The 52 F7 guy on Ford Barn said he had a parts truck that he recalled didn't have ribs. That's a far cry from evidence of a stock no-rib late cab. In this thread, I see nothing to prove smooth back cabs came from Ford after 49.
"This one doesn't have ribs because someone cut the back panel off and replaced it with flat sheet metal. It's entirely possible it originally had ribs."
Wayne, that is my truck and I think you are correct. I just discovered that panel when I removed the gas tank recently. That panel does not look factory to me.
#30
Ben, those are the ribs in the front panel of the bed. The ribs in question are the ones one back of the cab itself. Bye the way, the wood on your bed is fantastic !
