vacuum tree getting coolant
Old Mar 9, 2015 | 10:17 PM
FoxFord33's Avatar
FoxFord33
Ok, I've got white smoke from the exhaust of my 2004 4.6 expy. I thought it was a head gasket, but when disassembling I pulled the vacuum line off the vertical fitting on the front of the intake manifold and coolant poured out. the hose runs from there to the vacuum tree on the back of the throttle body. What stops the vacuum system from sucking coolant and getting white smoke that way? Should there be coolant in the vacuum line?
Old Mar 10, 2015 | 09:05 AM
alloro's Avatar
alloro
There's a good chance it's the intake manifold gasket needing to be replaced.
Old Mar 10, 2015 | 10:53 AM
FoxFord33's Avatar
FoxFord33
Good thing my kit came with all the manifold gaskets, too! I will check compression when I get more pieces off to see if I can be sure it's not the head gasket.
Upon closer inspection, I see that the coolant lines just run to a collar around one vacuum line, it's not a tree.
grizbait
Modular V8 (4.6L, 5.4L)
Sep 8, 2022 08:21 AM
86f1503004.9
37
Mar 21, 2016 01:35 PM
Chadloe99
1978 - 1996 Big Bronco
Jul 14, 2013 11:58 PM
ryanroo
May 15, 2012 12:00 PM
Ozark Pops
Apr 19, 2009 10:53 AM
