cab roof running lights
Old 03-09-2015, 12:03 PM
Outlaw56's Avatar
Outlaw56
Outlaw56 is offline
Has anyone had any luck finding a good set of quality running lights that fit the cab roof on a 56 Ford F-100 thru F-600 Cab? I would like to get a smoked lens look with either regular or led bulbs. I looked at Recon but some reviews discouraged my due to leak problems after installation.
Old 03-09-2015, 12:09 PM
Mixer man's Avatar
Mixer man
Mixer man is offline
Try taillightking.com Just got my set of bullets from AJ. Huge election.
Old 03-09-2015, 12:17 PM
Outlaw56's Avatar
Outlaw56
Outlaw56 is offline
Will do Mixer, have you installed yours yet?
Old 03-09-2015, 12:44 PM
Mixer man's Avatar
Mixer man
The last new green lens on earth.
Not yet, but they have nice rubber seals. Don't expect any leaks.
Old 03-09-2015, 12:49 PM
Mixer man's Avatar
Mixer man
These will take up a lot of real estate on the cab roof.
Old 03-09-2015, 01:05 PM
Outlaw56's Avatar
Outlaw56
Outlaw56 is offline
For sure, post photo when you get installed!
Old 03-09-2015, 01:18 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,726 Likes on 1,512 Posts
They are pretty but Those don't look period correct.
Old 03-09-2015, 02:09 PM
Elmo4895's Avatar
Elmo4895
Elmo4895 is offline
Old 03-09-2015, 02:21 PM
Outlaw56's Avatar
Outlaw56
Outlaw56 is offline
Thanks Elmo, good options. Especially the one that says it will fit both flat and curved roofs. That sounds like a good seal application. Im still trying to find some with smoke lens so they do not stand out as much, but will book mark these. I also want to be able to change out the bulbs from the top without removing the headliner.
Old 03-09-2015, 03:29 PM
Mixer man's Avatar
Mixer man
Not intended to be, but most everything else is. The tinted glass won't be correct either.
Old 03-09-2015, 03:40 PM
Outlaw56's Avatar
Outlaw56
Outlaw56 is offline
Im goint tinted rear on my rear cab window too mixer....no air in that one. LOL, F-250 Long bed, duallies and smoke stacks. Huge mirrors to see past the stacks mounted on the outside of the cab (not thru the middle of the floor). Sometimes a guy just has to do what he wants to do. I have two f-100 short boxes Im working on too. One is a hot rod and the other is pretty close to stock. They are all fun and they are all keepin me out of trouble.
Old 03-09-2015, 05:50 PM
Elmo4895's Avatar
Elmo4895
Elmo4895 is offline
I ran across some smoked ones when I was looking for some for my truck. I do not remember if they were on one of those sites or not. I will try to find them again and if so I will let you know. My 54 F 100 bed is toast with no fenders so I am thinking about a flat bed with stacks. Also thought about adding smoke. Sorta like the stunt planes use. You can have any color smoke that hits your fancy.
Elmo
Old 03-09-2015, 06:41 PM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is online now
Most times the 56's only had 2 in the front on the corners, this rig I have has 5 but they don't all match. I like the corner ones best
Old 03-09-2015, 08:19 PM
Sportster.Mark's Avatar
Sportster.Mark
Sportster.Mark is offline
The stock cab running lights on my '50 F6 look like this:
Here is a view stepped back a little:
And here is a frontal view:
I have three lights, not the DOT regulation five.
Old 03-09-2015, 08:37 PM
abe's Avatar
abe
abe is online now
I think back in the 40's and 50's each state had their own DOT laws regarding clearance lights. Some required 3 lights, some two (at the corners) while some required 5 lights depending on size and weight of the truck.
Since then, I think the Fed DOT has unified the laws concerning clearance and running lights.
Quick Reply: cab roof running lights
