Cam for carb'd 460 - towing
on
Here are a couple that might work for you, depending on the rest of your application.
http://www.compperformancegroupstore...y_Code=FHFTCHE
http://www.compperformancegroupstore...y_Code=FHFTCDU
For the timing gear you should just get a double roller set from napa/summit/wherever. If you tell them you have an '88-'97 460 they will give u a straight up timing set that will work fine in your motor.
BBpwer
03-30-2015 10:06 PM
RICHARD CLARK
05-10-2005 10:37 AM
Dyerstown
11-18-2002 07:18 PM
