Fuel Sending unit
Old Mar 9, 2015 | 12:30 AM
TheBEATTIE's Avatar
TheBEATTIE
Fuel Sending unit
So heres the problem. My front tank never worked, the truck would stumble then die. I didn't really care because I just ran it off the rear tank. But now the rear tank is starting to leak, so I'm going to drop the front tank and replace everything. Only one problem with that plan: I cant find a damn sending unit. I found one for a 92, but the connectors for the gauge are different. Heres the link: http://www.ebay.com/itm/1990-1991-1992-Ford-F-350-450-550-New-Fuel-Sending-Unit-Tank-Turbo-Diesel-/171306339841?pt=Motors_Car_Truck_Parts_Accessories&hash=item27e2a74e01&vxp=mtrDo you guys think it would work? The connecting tubes both cracked off on mine.
Thanks,
TheBEATTIE
Old Mar 9, 2015 | 11:03 AM
ironworker40's Avatar
ironworker40
1990 1991 1992 Ford F250 F350 F450 and F550 Turbo Diesel Sending Unit for 19 Gallon Side/Front Mount Tank
l Looks like the same place as the one you found on e bay. I spoke with this guy for a buddy of mine. He said ohm range was correct But tubes may need to be bent or lengthened. It looks correct for my 93 front tank. My buddy still has not fixed his gauge. There is also a rebuilder in ny. Rebuilt Fuel Sending Unit Specialist
Old Mar 9, 2015 | 12:01 PM
mf7lakes's Avatar
mf7lakes
+1 on TriStar
Old Mar 9, 2015 | 06:49 PM
TheBEATTIE's Avatar
TheBEATTIE
Alright I'll take a look at Tristar, but shipping from Canada might make it a little impracticable. So you figure it would work then, the one I linked?
Old Mar 9, 2015 | 09:15 PM
ironworker40
Yes I do but i'm not 100 percent . Plug may be different but that an easy fix.
Old Mar 9, 2015 | 09:16 PM
ironworker40
Yes I do but i'm not 100 percent . Plug may be different but that an easy fix. Check the ohms on yours they give u the ohm range.
Old Mar 9, 2015 | 10:13 PM
TheBEATTIE's Avatar
TheBEATTIE
Yah my truck has the round plug on the frame rail. And I dunno if it comes with the damn float. But my gauge unit works on the one I have (the broken one). Well I'll wait until I actually pull the tank and get the sending unit out before I order any parts. Thanks for the input!
TheBeattie
Gigemags05
47
Sep 27, 2018 07:39 PM
Odisvan
Apr 5, 2016 09:25 AM
JoeVR5
Jul 18, 2010 01:07 AM
welbo97
Oct 3, 2004 07:10 PM
Manwith3fords
Dec 8, 2003 11:20 PM
