Hard to start when hot
Old Jul 23, 2003 | 10:34 PM
Dofunny's Avatar
Dofunny
Angry Hard to start when hot
Hello to all
I have a 89 F150 two wheel drive four speed manual transmission and it has the fan blower that cools the injector when the engine get hot.
My problem is when the engine get hot it is hard to start and I have replace the starter twice and put a higher cranking battery in it also. The manual stated that the air filter could be some of the problem and I replace it and it didn't help any at all. I need some help bad.
Jack
riverrat@inteliport.com
Old Jul 24, 2003 | 01:45 PM
steve83's Avatar
steve83
Test the fuel pressure and the ignition coil - they're both sensitive to heat and known to go bad like that. Next thing would be the ignition module on the distributor. A Haynes manual tells exactly how to test each of them (and MUCH more).
