Help! Dead Excursion (no interior electrical)
Old Mar 7, 2015 | 10:22 AM
stumppullerny's Avatar
stumppullerny
Been lurking a long time for buying advice ...but now i'm hoping the forum can come though with some technical advice...
Long Story short...2000 Excursion (V10)...wouldn't start a week-or-so ago. No crank, no nothing. Used a jumper across the fender-mounted relay/solenoid...fired right up.
Must be a bad relay/solenoid...go to replace it. Of course the local auto store only has the "newer" 4 post models...no matter, should work just fine. Install it according to directions/install manual (which posts to use etc..)... doesn't start.
Take a second look at the wiring....while doing so, battery lead to solenoid slips across to other relay post...and makes me drop a little poo in my pants as the truck starts to turn over (i know, should have disconnected battery).
Get frustrated, think maybe the solenoid is fine, and there was an issue with the switch signal to the solenoid...maybe ignition is shorting...maybe neutral switch is bad (the way the shifter feels it wouldn't be a suprise).
Put original solenoid/relay back in...to trouble shoot. I now have no power, anywhere. I can short the battery to the starter and turn truck over, but other than that, nothing. No dome lights, no instruments, no headlights, not a thing in the interior.
I've run through every fuse i could find (under steering column, and in power box under hood) but everything looks good. Some wires that connected to relay had a fuseable link....that looks good too.
It's like i've killed a major circuit, but just can't find it. Any suggestions where to look next?
Old Mar 7, 2015 | 10:31 AM
Apocalypse's Avatar
Apocalypse
Really basic thing but did you smell any burnt wire when you were around the fuse panel?
Old Mar 7, 2015 | 10:43 AM
stumppullerny
No...but can't say with 100% certainty because of the cold i have. Still would probably be able to smell crispy wires though.
Old Mar 7, 2015 | 05:20 PM
05MilMachine's Avatar
05MilMachine
I have put those solenoids in wrong before on other vehicles and had that symptom. The main always hot feed to your fuse box might be on the wrong side? Turn your headlights on, jump solenoid to crank and see if the lights come on when cranking. To be fair, I don't know if the Ex is wired like that, just memory from old Fords.
TurboTuff
18
May 2, 2011 05:51 AM
fordf150farmer
Electrical Systems/Wiring
Feb 25, 2011 09:51 AM
tupton7
2004 - 2008 F150
Jun 27, 2008 06:01 PM
mooner
Dec 28, 2002 11:18 AM
