which truck would win in a pull off the 4.9 with 3.08 gears and a 4 spd. with granny, 8 ft. bed and two tanks or a 5.0 3 spd. with 3.08 and one tank and a 6 ft. bed
Originally posted by teederj2002 which truck would win in a pull off the 4.9 with 3.08 gears and a 4 spd. with granny, 8 ft. bed and two tanks or a 5.0 3 spd. with 3.08 and one tank and a 6 ft. bed
The one with the granny gear. gear reduction is everything
The gear ratio doesn't have anything to do with winning a pull-off. They're ALL about traction. Traction comes from the REAR tires; how they meet the surface they're on; and how much weight is holding them against that surface.
A lifted Suzuki would have NO trouble pulling a Lightning if the chain was short because the high hitch would steal all the weight (& traction) from the low one. If your wheels don't have enough weight on them, you could have 1,000:1 final ratio and it won't help.
