bolt size ?
Old Mar 6, 2015 | 08:08 PM
brutus67's Avatar
brutus67
bolt size ?
hey guys it may seem like a dumb question but does anyone know what size the bolt is that holds the adjustable alternator bracket on the bottom of the engine block on my 69 inline 6 300 I misplaced it somehow like trozei said bag and tag it hoping someone can help thanks in advance
Old Mar 6, 2015 | 08:49 PM
Randle's Avatar
Randle
I pretty sure it is 7/16 x 14. If nobody else chimes in I can look tomorrow when I go to the shop, then I can tell you length and all.
Old Mar 6, 2015 | 09:05 PM
brutus67's Avatar
brutus67
bolt size ?
thanks randle for your quick reply I am finally getting my 69 ranger to where I want it the rest is just cosmetic when I have the money I want to put djm drop I beams along with rear shackle kit I think my longbed will look cool lowered I don't know how to post pics I am hoping my son in law can show me. this old man aint smart when it comes to that lol once again thank you
Old Mar 7, 2015 | 09:46 AM
trozei's Avatar
trozei
I have four bolts in my alternator bag right now. (My engine is apart) Three are 3/8"-16 x 3/4" with a 9/16" bolt head. One is 7/16"-14 x 5/8" with a 5/8" bolt head. I believe the 7/16"-14 bolt is the adjuster bolt.
Old Mar 7, 2015 | 10:20 AM
Gembone's Avatar
Gembone
It should be the same size and pitch as the timing cover bolts, only longer to allow for the bracket.
Old Mar 7, 2015 | 12:31 PM
Randle's Avatar
Randle
7/16 x 20 1" long
Old Mar 7, 2015 | 02:34 PM
Randle's Avatar
Randle
Sorry it took so long to get back to you, but I had to haul the tractor to the shop and push snow to get up to the shop.
Old Mar 7, 2015 | 03:42 PM
trozei's Avatar
trozei
Originally Posted by Randle
7/16 x 20 1" long
Why do we have different sized bolts?
Old Mar 7, 2015 | 03:49 PM
Randle's Avatar
Randle
I don't know, I pulled mine out to check it and 7/16 fine thread is what is in it.
Old Mar 7, 2015 | 06:51 PM
brutus67's Avatar
brutus67
bolt size ?
once again thanks randle did not have a chance to get out this afternoon had to babysit my granddaughter but will go get one tomorrow
Old Mar 7, 2015 | 08:47 PM
trozei's Avatar
trozei
I don't think I have any threads finer than 18TPI on my engine...
Old Mar 8, 2015 | 10:26 AM
ultraranger's Avatar
ultraranger
I have a '69 F100 with a 240.
The large alternator pivot bolt in the upper bracket is 7/16"-14 x 4-1/4" long.
The bolt in the alternator, in the slotted portion of the lower bracket, is 3/8"-16 x 1.00".
The bolt at the inner end of the lower bracket, that attaches the lower (slotted) bracket to the front cover, is 5/16"-18. I'm not certain of its length because mine is bolted up. However, putting a tape on the outside and eyeballing it, it appears to be about 2.00" long, --give or take.
Old Mar 8, 2015 | 02:30 PM
trozei's Avatar
trozei
Okay, so we have the same bolts save for the lengths. My lengths are only measured on the threaded portions. How are you measuring length?
Old Mar 8, 2015 | 03:06 PM
Randle's Avatar
Randle
Sorry not getting back on quicker, I was admitted to the Hospital last night.
I got a feeling it's a model issue, what I measured was on the motor in my 70 which started life as a injected motor. I get out of here I will measure the on on my 92 and see what it measures.
Old Mar 8, 2015 | 03:26 PM
Gembone's Avatar
Gembone
Here is what my 300 (mid 70's) has holding the lower adjuster arm to the front of the engine
It is a 5/8 size head with 7/16" -14 NC coarse thread.
