2000 expedition front end problems
Old Mar 5, 2015 | 06:07 AM
qck46cobra's Avatar
qck46cobra
Hello. I have a 2000 expedition and yesterday morning drove fine. Sat at work and on way home had a bad vibration coming from front passenger side. Has new brakes and rotors. Can't figure out what it is. It is awd xlt. Thanks
Old Mar 5, 2015 | 09:46 AM
alloro's Avatar
alloro
Check around the edge of the rim for a clean spot. You might've lost a balancing weight.
Old Mar 5, 2015 | 09:50 AM
qck46cobra's Avatar
qck46cobra
I'll check when I get home from work. It's in garage on jackstands. Only thing I noticed last night was sway bar end link bushings are shot.
Old Mar 5, 2015 | 09:53 AM
alloro's Avatar
alloro
Did the vibration occur at slow, fast, or all speeds?
Old Mar 5, 2015 | 09:55 AM
qck46cobra's Avatar
qck46cobra
All speeds. It was fine yesterday morning. Sat in parking lot at work all day. Start it up let it warm up a Lil bit. Started driving heard a pop. It was OK for a Lil bit and wasn't real bad vibration then all of sudden couldn't do more than 20mph
Old Mar 5, 2015 | 10:11 AM
alloro's Avatar
alloro
In that case forget about having thrown a wheel weight. I would say something happened to either the tire, the CV joint, or the hub over there.
Old Mar 5, 2015 | 10:15 AM
qck46cobra's Avatar
qck46cobra
Yeah I'll get more info when I look into it more tonight
Old Mar 5, 2015 | 10:55 AM
alloro's Avatar
alloro
I hope that's a heated garage. I for one sure dread knowing that after I've worked all day, that I'd then have to go out in the cold and lay on a creeper.
rob9771
Jan 21, 2013 06:37 PM
primas75
1997 - 2003 F150
Dec 29, 2008 12:04 AM
cool_hand_luke
Nov 23, 2004 10:14 AM
