Coolant Filtration
Old Mar 5, 2015 | 04:39 AM
gwcon's Avatar
gwcon
Coolant Filtration
Any of you folks running a coolant filtration system? If so, what brand and are the filters catching enough debris to make it worth while? If not, what is your opinion regarding this add on?
Thanks in advance for your info and opinions.
Old Mar 5, 2015 | 05:46 AM
UGA33's Avatar
UGA33
Nothing wrong with peace of mind. I think I have only seen one person with a 6.7 have one. He mounted the filter on the frame of the passenger side. Believe it was homemade. Have you checked with Dieselsite?
Old Mar 5, 2015 | 06:15 AM
djousma's Avatar
djousma
I had one on my 6.0L from dieselsite. It probably saved my egr cooler. Was debating putting one on my 6.7L, but decided it didnt need it. Havent heard of anyone with failed coolers. A lot of failed radiators, but a filter wont stop that.
Old Mar 5, 2015 | 06:20 AM
gwcon's Avatar
gwcon
The Dieselsite unit was the one I am considering.
Old Mar 5, 2015 | 06:23 AM
gwcon's Avatar
gwcon
From the info on Dieselsite it saves a lot more than coolers. I know they are trying to sell things but their write up on the benefits is enticing. I just don't know if it more than a sales pitch.
Old Mar 5, 2015 | 09:20 AM
UGA33's Avatar
UGA33
6.7s are a different breed and don't seem to suffer from the same cooling system woes the last two engines had.
Old Mar 5, 2015 | 09:27 AM
Blapensee's Avatar
Blapensee
i made one with the dieselsite coolant filter head https://www.ford-trucks.com/forums/1...installed.html
and id like to add that i ended up taking most of it apart removing the teflon tape and going with some arp thread sealer made for coolant
Old Mar 5, 2015 | 10:03 AM
ruschejj's Avatar
ruschejj
Hey gwcon, you're acting like you may keep your current truck for a while. You and I have been hanging around here for a few years and I've noticed that you go through trucks faster than I go through work boots, lol.
Are you making plans to keep your truck for the long haul?
I've never had any coolant issues in my years with the 6.7. Would it help with keeping the coolant pH right? I did blow the radiator once in my 2011 truck which we know is common, is there some way to prevent that happening? Does the filter system help with the pressure/flow/cavitation which may cause these leaky rads?
Old Mar 5, 2015 | 10:13 AM
Mishimoto's Avatar
Mishimoto
Former Vendor
Yes, as mentioned by UGA, the 6.7L does not seem to experience the issues we saw with the 6.0L. That being said, peace of mind is certainly nice to have. Has anyone with a 6.7L coolant filter setup cut open the filter to check the debris/contaminents?
We recently launched our 6.0L kit and we are just about ready to launch our 6.4L kit. The 6.7L may be next on our development list depending upon how necessary it is.
Thanks
-John
Old Mar 5, 2015 | 10:33 AM
Blapensee's Avatar
Blapensee
i have a new filter on the way as soon as it gets here i will be cutting up the old one we shall see
Old Mar 5, 2015 | 11:42 AM
UGA33's Avatar
UGA33
Looking forward to that.
Old Mar 5, 2015 | 11:56 AM
17 Oaks's Avatar
17 Oaks
I know little about diesels!
But in the V8 chevy world those water pumps do not expect there to be a filter in the system. It could be possible that a filter would slow down the flow enough to create cavitation and they will result in overheating.
In addition the pump blades are designed too move coolant at optimized rpms. In other words the pump on X engine is while may fit and work, it may not work properly due to different performance at different rpms.
I would be very cautious about adding a component to a system that was never designed to use it, therefore no existing parameters to integrate into. Just my opinion.
Old Mar 5, 2015 | 12:49 PM
ruschejj's Avatar
ruschejj
Hey don, there are folks here that know better than I but for some reason aftermarket folks have been designing coolant filter systems for powerstroke diesels for over the last decade. There are thousands who felt that they were helpful on the 6.0 diesel.
I understand what you're saying about pump designs and the engineering of coolant flow and temperature management which are huge factors in the current 6.7 engine design. These new diesels rely heavily on heat to run properly and control emissions which leads me to believe that temperature control is vital. With the two independent cooling systems we have I would also be wary of messing around with it.
Old Mar 5, 2015 | 02:27 PM
17 Oaks's Avatar
17 Oaks
x2
Its def a complex engine and its those points that I would need to have those questions answered.
I have not been in several years but I go to SEMA and the Off Road Expo in Pomona Ca and have for years. I don't care what you drive there is no shortage of install this and you car can get 300 mpg, increase of 1000 hp and a jillion other things. How many remember: Toilet Paper oil filters; magic pellets you put in your cyl and it would rebuild your engine, gasoline additives that would double your mpg etc etc etc. Ask them how does it work other than by magic and you rarely got any answer that would pass any test.
I have heard it all: 'my mother, she is a virgin', 'don't worry my husband is working the night shift', sure I take birth control, my 4 kids were all planned'...CAUTION is the watch word.
Old Mar 5, 2015 | 05:36 PM
69cj's Avatar
69cj
If set up the same way as in the 6.0, it will be a bypass filter and will not impede the water pump flow even if totally plugged up. Don't forget you have two cooling systems on the 6.7.
