Ignition Conversion
Old Mar 5, 2015 | 01:08 AM
scb1966's Avatar
scb1966
Smile Ignition Conversion
My 1966 F100
Bone stock 240, what a powerhouse
I am considering converting my point type ignition to a pertronix or a duraspark system. The duraspark looks cheaper to obtain as my local pick a part has many to choose from but I am clueless about the conversion. I assume the 300 is a direct swap for the 240.
Old Mar 5, 2015 | 07:38 AM
daveengelson's Avatar
daveengelson
If I have not already done so then let me take the opportunity to welcome you to FTE!! Great looking truck!!
Once priced out don't believe one will find there's much difference in cost. I went with the Dura Spark ll but it requires wiring in a circuit for the system; whereas, with the Pertronix, I understand the main advantage is its ease of installation. The topic comes up on occasion and seem to recall majority, if not all, of the member's who swapped over to Pertronix are very pleased with the conversion. I am certain other member's will be chiming in with comments and advice, you will be please with either Electric Ignition system, no longer a task to start the engine on a cold winter morning. Again, welcome, looking forward to your input.
Came across a 'testimonial' thread: https://www.ford-trucks.com/forums/1...-ignition.html
Old Mar 6, 2015 | 10:37 PM
DoubleOh7's Avatar
DoubleOh7
I've converted to both over the years, but went with Pertronix for most of them until I could not get it to work correctly on my '67 352. After a few hours of forth and back with them I sent the unit back for diagnosis, which they return to me a new one yet reported nothing found wrong with the one I sent them. When the new one worked no better I went to new DSII dizzy. Because I like to tinker with what isn't broken I found threads about using GM HEI modules instead of the DSII modules. Easy wire-up and runs a charm. But you could go either way. The amount of wiring is about the same.
The only reason I'm doing DSII and GM module on my new 66 352 is because it is so easy and I needed a new dizzy anyway. I had a Mallory dual-point dizzy on it and needed a new stock one, and a later model FE DSII dizzy on RockAuto was cheaper than a Pertronix kit and a GM module is cheap as well. Though this time I put the module in a DSII box.
[Edit] I think with all the stock points stuff intact, the Pertronix is easier to do. You have to get switched 12 volts to the red wire while running the coil off the resistor wire of the stock system (the coil isn't made to see 12 volts all the time). DSII is a 6 on the 10-point difficulty scale and Pertronix a 2. That may help you decide as well.
Old Mar 7, 2015 | 09:03 AM
Jdeshler's Avatar
Jdeshler
Originally Posted by DoubleOh7
I went with a hei distributor but this is the way to go if you want to keep the stock look
My hei
Old Mar 7, 2015 | 02:40 PM
DoubleOh7's Avatar
DoubleOh7
That looks like the DUI system from the pic. I've never hooked them up before, but I'm not a fan of the look so never gave them a chance. The 69 Mustang w/351w I'm building the owner bought the Pertronix III, shiny dizzy, and the thing is so tall along with their cap style - the 14" air filter plows right into it. He's now got to get a new air cleaner. Not so much an issue on the 240 6'r. ;-)
Old Mar 7, 2015 | 08:13 PM
Jdeshler's Avatar
Jdeshler
It is tall but its 100% trouble free and for 75 bucks it was a pretty sweet upgrade.
1984_F-150
May 4, 2023 10:37 PM
Idaho Highboy
44
Mar 12, 2018 10:34 AM
pucry
Oct 19, 2014 05:11 PM
BradyCouchman
Mar 4, 2009 12:14 AM
70_f100
Aug 20, 2005 12:48 AM
